Hey djbird3
thanks so much for sharing... How far have you gotten with that spindle speed control? I too have an SX2 and have cnc'd it, modded for more y and Z travel and stiffened coloumn... NOw I want to CNC spindle but not sure if the digispeed will do the trick since this is a different control board than the X2. This one controls a brushless motor which is quite different. I wonder if the pot works the same as the brushed X2? If you can figure it out please let us know. I'm planning on ripping my beast apart and spending some quality time with a voltmeter in my lounge
Your help is totally appreciated!
P.S. I used Hoss's plans for my conversion.... Look into getting bigger balls for your ball screws and also make sure you make your gibs and table real smooth so you can tighten the gibs nice and tight. relaly helps with backlash and a nice smooth cut.
