587,249 active members*
3,592 visitors online*
    Nov 2017
    Lms spindle control 4213 G540
    I am new to cnc machining. Currently working on a LMS 3960 cnc conversion. Could someone spoon feed me how to wire and connect the lms 4213 spindle control module to the Gecko G540? Also, supply the settings for Mach3.
    Currently
    1. I have x, y, and z.axis operational with the g540 and mach3.
    2. I have changed the chip on the lms spindle control board.
    3. I have gotten the 4213 to control the spindle. I followed the wiring diagram and did the jumped the module. I could manipulate the spindle speed with the W1.
    I could not mach3 (M3) to turn on the spindle. Please provide novice level instruction and or pictures.
    Jul 2012
    21
    Re: Lms spindle control 4213 G540
    did you ever get it working? im at that point as well and cant get mach3 to turn on my spindle
  1. G540 spindle control.
    By krakenatwork in forum Gecko Drives
    Last Post: 05-08-2017, 05:12 AM
  2. Spindle Wiring and Control with G540.
    By OrangeClockwerk in forum Avid CNC
    Last Post: 07-27-2014, 06:32 AM
  3. Another G540, X2, Spindle control problem
    By CerveloRod in forum Benchtop Machines
    Last Post: 05-23-2013, 08:22 PM
  4. Is it possible? (G540 spindle control)
    By fretsman in forum Gecko Drives
    Last Post: 10-14-2009, 12:27 AM
  5. Spindle Control Through G540
    By john1285 in forum Gecko Drives
    Last Post: 09-30-2009, 04:26 PM
