587,775 active members*
2,860 visitors online*
Results 1 to 1 of 1
    Jun 2008
    20
    LOBE TURNING?
    Turning a Pentalobe on a Citizen E-32, anyone ever done it? There is a G code for polygon machining but I'm not sure how to use it. G114.2 is supposed to turn cam shapes but I've never used it. Not only do I have to turn a profile (attachment - pic to the left - the tip) to come out as a pentalobe (attachment - pic to the right - not a diameter), but I also have to turn the threads to follow the surfaces shape (minor thread diameter in red). Any advise on how to turn a cam would be helpful. With that info I might be able to figure out how to thread it. Thanks any & everyone.
    Attached Files Attached Files
  1. Turning 17-4 PH?
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 12-18-2014, 01:56 PM
  2. Funny shaped Cam lobe
    By stevehuckss396 in forum I.C. Engines
    Last Post: 02-15-2010, 12:02 AM
  3. Turning Cam
    By Regnar in forum Uncategorised CAM Discussion
    Last Post: 04-29-2008, 10:27 PM
  4. RFQ - 304 SS Turning Job
    By JMFabrications in forum Employment Opportunity
    Last Post: 10-31-2007, 03:23 PM
  5. Lobe turning in/near S/E Michigan
    By NC Cams in forum Employment Opportunity
    Last Post: 11-17-2006, 06:46 PM
