587,485 active members*
3,199 visitors online*
Results 1 to 6 of 6
    May 2010
    7
    Long Boring .600 diameter hole
    We are quoting a job that has a .600 flat bottom hole 8.125 deep. tolerance on the hole is + - .005. Any suggestions on how to accomplish this?
    Thanks In Advance
    May 2003
    323
    Make a flat bottom drill.
    First make sure there is a hole.
    May 2010
    7
    That's the easy part the hard part is the .600 diameter
    May 2003
    323
    Take a 39/64 drill spin it down with little bit back taper and use it like a reamer.
    You can put radius or chamfer to lead it in.
    May 2010
    7
    That's what we have been considering. Now I just need to find an aircraft drill that size.
    Nov 2006
    303
    uh huh, and my very first question would be right back at the customer, WHY? I find it very common that cute little green horn engineers like to design stuff with absolutely zero clue about manufacturing and it ends up costing the customer. It could very well be this is a shaft bore where the mating shaft could have a nice chamfer which would easily allow a chamfer of a reamer in the bore.
  1. Conical Boring 6.968" diameter, down to .250" diameter, over a 7.776" length
    By HaroldSAJS in forum Mechanical Calculations/Engineering Design
    Last Post: 06-08-2012, 09:29 PM
  2. Multiple diameter step drilled hole.
    By frogier in forum MetalWork Discussion
    Last Post: 03-28-2012, 08:21 PM
  3. how to find cutting diameter of boring tool
    By autobot in forum MetalWork Discussion
    Last Post: 01-27-2012, 12:55 PM
  4. 1/2" DIAMETER T-Slot cutter with long shank?
    By panaceabea in forum MetalWork Discussion
    Last Post: 08-29-2009, 12:40 AM
  5. Enlarge internat diameter in long tube.
    By asuratman in forum MetalWork Discussion
    Last Post: 04-06-2006, 06:19 PM
