I'm trying to turn 316 ss down to .030 and aprox 1.150 in lengh. The part in getting bent during the turn and was looking for some advice. thanks
If you're using a chucker try going for the finished diameter from stock size, working your way toward the chuck. A collet would help.
Or you could rough & finish a short section at a time, working toward the collet.
If that doesn't work, stick it out say 1/4", rough & finish, stop, stick it out another 1/4", repeat. Keeping the stock indexed to the collet would help (mark it along the length).You need the support of the stock to make this part. Thats why it's a good candidate for Swiss, where the stock is supported right next to the cutting tool by the headstock bushing.
