I am trying to repair an OK grinder with a Acroloop 1500 motion controller. The origional Mfg. sold out to Parker Hannifin and no longer support this control. Anyone have one of these things laying around?
I have the 8000 & 2000 cards, was the 1500 a stand alone or in a ISA slot?
What is wrong with the 1500?
Al.
Albert E.
The card has an ISA edge card connector but is installed as a stand alone unit. It receives it's data from a control computer via RS232 com line. The problem is a failure of the X axis control to send a axis ready message to the control computer. the Y axis will pass the test if the order of the card test is changed but will hang on the X test.
Its been a while, but do you have the serial communication program for checking direct to the card?
IOW, interrogate the card and give commands etc.
Al.
Albert E.
