587,997 active members*
2,022 visitors online*
    Mar 2010
    24
    Looking for a budget water/laser
    Hi guys, new to the forums here. I currently have a 6x12 Dynatorch CnC table. Oxy torch, 150 amp plasma, engraver, and exhaust fan setup. I like working with plasma, it's just that I have highly detailed parts for custom PC's and whatnot that I need to make for customers. Most of the time I have to source these out to someone with a waterjet because the plasma just can't cut them due to the thick cut and the heat generated. What are some good budget laser or waterjets? It doesn't have to be a large table. The biggest stuff I would work on would be maybe 4'x4', if that.
    Feb 2006
    1260
    Quote Originally Posted by Shrimp View Post
    Define budget?? Neither laser or waterjet come cheap. How thick & what is the material you need to cut?
    If it works.....Don't fix it!
  1. Laser Vs. Water Jet?
    By FanucGuru in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-01-2010, 02:22 AM
  2. another water/laser rough out
    By zcases in forum Employment Opportunity
    Last Post: 10-10-2008, 01:35 AM
  3. Laser/Water SS Stencil
    Last Post: 09-26-2008, 11:22 AM
  4. Laser/Water SS Stencil
    Last Post: 09-21-2008, 12:03 AM
  5. RFQ - water/laser jet 316SS
    Last Post: 01-09-2006, 11:39 AM
