603,383 active members*
3,596 visitors online*
Results 1 to 19 of 19
    Oct 2007
    8
    Looking to build a CNC machine
    I'm looking to build a CNC router for cutting steel panels upto a max of 2mm thick, i was just wondering if you could point me in the right direction for a good, easy and preferably cheap DIY CNC machine.
    Thanks in advance
    MitchDM.
    Sep 2006
    318
    What size work area are you looking for , and what material do you want to build your machine from wood , mdf , steel aluminium?
    Drakkn Custom Shop http://www.drakkncustomshop.co.uk
    Oct 2007
    8
    Im not to bothered if its bigger but the biggest i will need it 700mm x 700mm.
    Im not to worried what material, just needs to be pretty cheap, but without compromising too much on accuracy.
    Was just wondering if anyone could point me in the right direction.
    Thanks for the reply
    Sep 2006
    318
    jrgo machine could be the way to go check out the threads there are loads of them
    Oct 2007
    8
    It certainly looks like it could do the job nicely, how much can i expect it to cost to build? and what electronic bits would i need for it to cut steel?
    MitchDM
    Sep 2006
    318
    I think some of the jrgo threads deal with costings the cost of the mdf will not be too great ,I think you need a a max of 2 8x4 sheets which is about £65 then you need some rods,bolts etc
    then a psu and load of motors etc which I guess around £35O ...its my guess you need £5OO ish all in all,but I maybe way off.
    May 2007
    14
    Quote Originally Posted by mitchDM View Post
    MitchDM
    Youll never cut steel on a JGRO.
    Oct 2007
    8
    Quote Originally Posted by Bartsimsonii View Post
    It is only 1mm thick maximum.
    Sep 2006
    318
    you could use a mdf machine to make a steel machine
    Oct 2007
    8
    Quote Originally Posted by Drakkn View Post
    It is certainly a plan as i'm not too good as working with metal, is there anyone else who thinks the MDF machine wouldn't be suitable for cutting steel?
    Thanks for the help guys, hopefully before long i'll be able to build one, i have used a denford machine before at school, but the idea of having my own is even better.
    Sep 2006
    318
    Hi
    I started to build a jrgo and got sidetracked with this build
    http://www.cnczone.com/forums/showthread.php?t=37139
    I am nearly done now - maybe something along these lines
    Mar 2003
    35494
    For one, cutting steel requires lots of coolant, which doesn't mix well with MDF. And second, while it's a decent machine for light work, most who build the JGRO find that is flexes too much, and eventually build another machine. If you'll only be cutting steel, you might want to look at building a plasma cutter.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2007
    8
    How expensive is it to build a plasma cutter (sounds expensive) and are there any plans you would recommend i can look at or buy?
    Apr 2005
    3634
    The cheapest thing your going to cut metal with is a oxy torch, the good news is you can cnc the torch, & stay low budget.
    http://www.cnczone.com/forums/showthread.php?t=24187
    Apr 2005
    3634
    You could start cheap with the oxy torch, than upgrade later on to a plasma with a few mods. to the table.
    Oct 2005
    278
    Switcher is completely right.
    there's no sense in building a machine dedicated to cutting steelPLATE by means of milling.Some kind of torch is the way to go wich is a very big plus because a torch cutter will cause a lot less stress and pulling forces to your frame except when rapiding and other fast moves wich means you can save by using smaller motors then when milling and keep your design "lightweight".If you want to use the machine for a long time i wouldn't recommend mdf cause it will deform and all the gasses from the bath underneath your workpiece could eat into it.
    Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
  17. #17
    Oct 2007
    8
    Thanks for the advice, i'll have a look around and see what i can come up with.
  18. #18
    Oct 2007
    8
    @ Switcher - How good is the finish on the cut, from what i can see it seems quite rough.
  19. #19
    Oct 2005
    278
    when cutting with plasma you'll have to change gas/mix ratio's and pressures according to the material at hand to maintain a clean cut
    When thight tolerance is required finishmachining on a mill/lathe is unbearable for as far as i know plasma torches can't cut with hundredths of an inch precision and my guess would be that the heat will cause some deflection.
    If looks are all that matter sandblasting polishing or a vibratory polisher would be sufficient.
    i haven't got any experience with plasma cutting myself and all above i have read here at the zone and interpreted as good as i could.
  1. New CNC machine build (big pics)
    By ckm in forum Vertical Mill, Lathe Project Log
    Last Post: 04-30-2012, 11:49 PM
  2. mvaughn's 2nd machine build
    By mvaughn in forum CNC Wood Router Project Log
    Last Post: 01-03-2010, 02:53 AM
  3. Use the second machine to build the first!
    By Madclicker in forum CNC Wood Router Project Log
    Last Post: 06-27-2007, 05:29 AM
  4. Buy commercial machine for 6k or build your own?
    By Menatep in forum Commercial CNC Wood Routers
    Last Post: 04-09-2007, 03:26 AM
  5. Want to build new machine
    By thuffner3 in forum CNC Machining Centers
    Last Post: 02-14-2004, 03:47 PM
