Re: Looking to buy old laptop with SRAM compatible PCMCIA slot
There is a lot of old hardware (and some still being installed) out there that can be easily programmed by PC (if you have the codes) using an RS232 port. I hoard my old laptops with RS232 ports on them. I think I have a few of those old beaters. Batteries are only good for an hour or so. CMOS batteries are dead. I have to plug them in and then do an auto configure and set the date every time I use them, but... Keys are missing from one. Last time I bought one I bought two because I knew this was coming. I bought my last several RS232 enabled laptops refurbished. Last time I checked none of the regular refurbished resellers had any. You might try Craigslist or Ebay and see what you can find. Be prepared to buy a couple and make sure you are getting system disks or have a licensed OS you can install. You will probably have to spend half a day cleaning it up if you don't buy it from a professional refurbisher.
Remember that Microsquish no longer provides any support or security support for XP machines. In addition most browser developers no-longer provide support for XP machines. There was a hack (registry edit) to make your XP machine look like XP embedded so you could continue to receive security updates, but I think that expires or expired this year. The point is the moment you put your machine on the Internet it is instantly at risk.
Tiger direct has some adapters for PCMCIA. Go CNA (cnaweb.com) has always had a lot of older hardware too.
Bob La Londe
http://www.YumaBassMan.com
