588,481 active members*
4,726 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Looking for CNC machine to cut EPS panels
Results 1 to 4 of 4
    May 2009
    Hi All,
    I am looking for a supplier or importer in AU that can provide a CNC machine to cut EPS or PIR refrigeration panel.
    Panel thickness varies between 75mm and 150mm with a 0.6mm metal skin.
    Ideally this would consist of a bed of around 4m long by 1.5m wide with a gantry using either laser or traditional router and saw blade.
    The panels are required for small buildings so i need a machine to cut out widows, doors and electrical penetrations etc.
    Maarten
    Re: Looking for CNC machine to cut EPS panels
    if without steel parts ,thickness is witih 100mm , chose digital knife or hot wire cutting machine .
    100mm EVA Foam with POT knife head
    https://youtu.be/4f8cxExm14k
    but for 150mm thickness, suggest you choose cnc router
    https://www.youtube.com/shorts/MkipINORLmE
    if you want to get more info ,contact with me by whatsapp +8618560201508
    suggest 75 to 100mm use Pneumatic oscillating cutter head? cutting edge will be very smooth .
    100 to 150mm , choose spindle , whole Z axis working area will be 400mm , foam 150mm , router bits 160mm ,
    What do think this solution ?
    wall foam insulation sound insulation cotton auto loading cutting machine
    https://youtu.be/p5R41GZ9c8U
  1. cnc foam cutting machine for mold eps
    By cncrouteratc in forum News Announcements
    Last Post: 03-29-2014, 04:07 AM
  2. Trying to do V cut LED panels
    By Milenabm in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-17-2013, 09:24 PM
  3. CNC machine for EPS/EPC mould process
    By wyl6362708 in forum Videos
    Last Post: 03-14-2012, 06:45 AM
  4. CNC router used to cut out square panels !
    By killersoundz in forum DIY CNC Router Table Machines
    Last Post: 12-16-2011, 06:33 AM
