588,121 active members*
4,873 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Looking for cnc mill top design sugestions
Results 1 to 7 of 7
    Oct 2008
    1147
    Hi all. I'm currently building a cnc mill to work in metal. My mill head is on it's way but I still haven't designed a table top to use with it. I plan on a lot of wet cutting. I'm stuck on how to collect the fluid. There seems to be two methods for fluid control. Option A, sit your machine in a huge pan to catch the fluid. Option B, have a pan on your table top. I like option B better but I haven't found any pans that'll fit it (25"x8"). SO I'm thinking something custom will be needed to be made.
    I'd really like to go with 1inch piece of aluminum for a table top and machine t track into it or machine slots to mount some t-track in. I'm posting some design ideas I have.
    Aug 2008
    1166
    You might try posting this in the metal working forum...
    Oct 2008
    1147
    You're probably right. However, after reading on the topic some more last night, I think I'm going to give just dry cutting a try first. Carbide's are cheap enough that I don't think I'll need to use HSS endmills that would need flood cooling. Guess I'll see how it goes.
    Apr 2007
    8082
    Would something like this X-Y cross table from Grizzly Industrial be of any interest? It is essentially a milling machine base without the column and milling head. T-slots are included, oil drain is included, and the ACME screws can be changed to ball screws. Standard low cost clamp sets and fixturing works with it. Cast iron construction.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Oct 2008
    1147
    Quote Originally Posted by CarveOne View Post
    CarveOne
    I may go that route if I fail, actually I'll probably buy a mill and convert it, but I already have my linear components and frame together. I'm too vested to turn back now. lol
    I think this weekend I'm going to try and make the table pictured above the 1 inch aluminum plate out of some TREX stock I bought last weekend. If I like the feel and functionality of it, then I'm going to order some aluminum stock and mill it.
    I think I'm going to find out just how good Ahrens roller assemblies are.
    Aug 2008
    1166
    I would highly recommend way guards. They'd be easy to add to your design.
    Oct 2008
    1147
    Quote Originally Posted by jsheerin View Post
    Way guards are in the plans for sure. I'm thinking about making some out of plexi that slide over each other and deposit swarf at the the ends of the axis's. The acordian style does seem like the easiest to implement though.
  1. I need sugestions on what lathe tool to use
    By ryansuperbee in forum Uncategorised MetalWorking Machines
    Last Post: 08-12-2008, 12:36 PM
  2. need sugestions on type of cutting bit to use
    By ryansuperbee in forum Mini Lathe
    Last Post: 08-11-2008, 03:39 PM
  3. sugestions!
    By watzmann in forum Community Club House
    Last Post: 01-02-2007, 11:05 AM
  4. CAM software sugestions for Prototrak?
    By rictek in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-25-2006, 07:59 PM
  5. New and need sugestions on a mini mill
    By 691175002 in forum Benchtop Machines
    Last Post: 05-23-2005, 07:09 AM
