Hello again:
I'm now moving up from cutting aluminum to cutting steel. I was wondering if you guys could give me some ideas as to what you consider an acceptable depth and width of cut? I'm going to be cutting some .5 inch thick cold rolled steel. I need to remove a lot of material. Can I cut full depth and if so what width of cut can I get away with. I wish I could just trace around the profile but the material being removed would likely trash the cutter when it broke free. I have for roughing a .375" Cobalt four flute rougher. To finish I was planning on using one of my 3 flute end mills I use for aluminum. I know the finisher is not ideal but its what I have.
I know there are online calculators but I have not had much luck with those. I find if I play with the numbers to maximize the cut I end up with a chattering end mill. Anyway just looking for some rough idea about where to start. I can optimize things later.
Tom
