New machine and I do not know how to run it
Thought I would start with somthing simple just a few letters.
The torch comes down finds the plate rises to pierce hight fires does the pierce and goes out one out of six or so times the rest of the time it cuts as it should.
I have stop at lost arc unchecked.
changing settings does not seem to make a difference.
the air pressure is holding ok
Could be the frist cut could be the fifth or what ever.
Is this a noise issue.
With stop at lost arc cheked it don't want to run at all.
I have not called dynatorch yet just thoght some of you mite have an answer.
