587,789 active members*
4,274 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Looking for info: Tree Journeyman 465
Results 1 to 6 of 6
    Oct 2004
    49
    Looking for anything I can find on this machine.
    I'm looking at one locally which apparently had a control conversion done some time ago and is now inperable. Not much for details yet, but hope to have more soon.
    Any links/pics/references appreciated.
    Jim
    Feb 2009
    6028
    Never heard of one, and I worked for the dealer. Sure it's not a J425?
    Oct 2004
    49
    I have a little more info now, but will go by and look at it this afternoon to verify the model #.
    The machine was retrofit at Delta Tau with a PMAC controller, Quad Amp, and Yasakawa servos.
    I will obviously find out more in person than by email, but is it possible this machine was a manual mill previously and was converted to CNC or is it more likely the controls were just retrofit?
    A lightning strike took it down, so there's no telling what I'm looking at for repairs...
    Feb 2009
    6028
    My guess would be it was a J425, solid tank of a knee mill, only came 3 axis CNC with ballscrews and box ways. All of them i've seen had Dynapath controls, but it it possible it was actually a Tree Millennium (very short run) that had centroid controls on them.
    Oct 2004
    49
    Stopped by and looked at it today, sure enough, it's a J425. It's tucked back in a pretty tight area in an auto repair shop and the owner of the machine wasn't there, so I couldn't get inside of it to look at anything. However, the controls are all Delta Tau and it has an Advantage 810 operator panel and some sort of PMAC controller. Hard to tell what when the guy showing it knows little more than "I've seen them use it a while ago", but it does look like a pretty beefy machine.
    The quad amp was removed and laying on the work table, so I can only assume some level of troubleshooting was done, but not sure if that would be better or worse.
    The machine looks to be in decent condition, but I haven't bought a machine in 15 years and that was practically gifted to me. Anything I should look out for on a 425?
    I'm electrical in background, so not worries about that end, just not sure about surveying the machine. They're asking 1200 firm, but that seems high for a machine with questionable cost to repair.
    Any thoughts?
    Feb 2009
    6028
    Seems a little on the high side for a non functional machine. If the Yaskawa spindle drive is toast ( these were factory BTW) your looking at 1200+ to fix it, 2500 for a new one. Delta Tau parts can be had on Ebay relatively cheap, but you need to make sure you get all the PLC programs and prints with it, otherwise you will be starting from scratch.
  1. help tree journeyman 325
    By cnc beginner in forum Tree
    Last Post: 03-05-2014, 07:13 AM
  2. Info request; Tree Journeyman 200U
    By lumberjack_jeff in forum Tree
    Last Post: 02-21-2010, 04:13 AM
  3. (NEED HELP) TREE Journeyman 250
    By tspowell in forum Tree
    Last Post: 03-31-2008, 03:11 PM
  4. Journeyman 325 Tree
    By dalesails in forum Tree
    Last Post: 08-31-2007, 11:54 PM
  5. Tree Journeyman 310
    By Gyro in forum Tree
    Last Post: 07-20-2007, 12:40 AM
