587,737 active members*
3,080 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Looking for a lathe tool for this part. Need some guidance
Results 1 to 7 of 7
    Feb 2006
    42
    Trying to find a tool to cut this part. Anyone have an idea on what I can use. I need the tool to cut the female part on the face.
    [IMG][/IMG]
    Oct 2009
    118
    You will need a full radius trepan tool. Can't tell you much more without dimensions from your part.
    Jul 2005
    12177
    Feb 2006
    42
    Thanks for the link Geof!
    The part is 6.900" diameter. From the face to the bottom of the radius is around 2". It is only .889" from the flat to the bottom of the radius.
    Dec 2009
    13
    Another possibility is a 93x35 degree turning tool. If you have one laying around and ground off some radial clearance, they work good. (As long as that outer angle is greater than about 40 degrees off centerline of part.) Just a thought.
    Jan 2007
    1389
    Depending on what the rad is on the od corner, you might need 2 treepan tools one to do the OD and the other to do the groove.
    Those iscar ones work great. Sandvik has some good ones also. ive used them both with equal results.
    Delw
    Apr 2011
    Delw is right.
    You are going to need two tools.
    One a full radius trepan in a boring bar style. It will need to be the boring bar style because of the depth of the big radius. The OD styles won't go that deep.
    It would probably also make sense to run a boring bar along the hub and blend the radius at the bottom. If you use the full radius tool for this feature it will chatter and the chip control will be horrible.
    Iscar is the best choice for facegrooving/trepan because they have the greatest variety although their catalog is impossible to read...
  1. tool sucked into part?
    By encarlisle in forum Fadal
    Last Post: 06-27-2009, 05:08 PM
  2. tool sucked into part
    Last Post: 06-24-2009, 11:22 PM
  3. Guidance in purchasing a metal lathe w/ auto feed
    By ZPenn in forum Want To Buy...Need help!
    Last Post: 05-21-2009, 12:00 AM
  4. How do I set up part zero and tool offsets on a CNC mill?
    By AccuMillGuy in forum Uncategorised MetalWorking Machines
    Last Post: 04-22-2009, 12:47 AM
  5. how to for 94 haas vf3 tool and part probe
    By lapuser in forum DNC Problems and Solutions
    Last Post: 01-13-2006, 06:43 PM
