587,180 active members*
3,564 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Looking for Metric endmills - Extra Length
Results 1 to 12 of 12
    Mar 2008
    454
    Hello,
    I am having trouble finding extra length endmills in metric sizes.
    My current tools are only about 50mm OAL, but I really could use more like 6 inches.
    I would like to get sizes:
    3mm
    6mm
    10mm
    I have found several web stores that have OAL of 6" on TIALN bits, but they are all standard sizes... I will use standard if it's impossible to find metric, just hoping someone would have a recommendation.
    This is the closest I've found to what I'm looking for.
    http://www.tjgrinding.com/endmills.php?series=110
    Thanks!
    J
    Jan 2010
    Talking Extra Length Metric End Mills
    Take a look at these two sites;
    Carbide Cutting Tools Specialty Tooling Belleville Mi
    Home
    It looks like they offer tools in the sizes you want & a little longer than what you currently have.
    You might also consider calling and getting a quote on a "special order " for the lengths you require in the configuration you desire.
    Kenny
    Mar 2008
    454
    Sorry but both of those dont really have any extra length.
    3mm = 50mm OAL (same as I already have)
    Thier 6mm extended length = 75mm OAL, my normal one has 65mm OAL.
    Thank you for trying though, some interesting bits in there
    Nov 2008
    129
    Extra long milling cutters
    I would suggest you look at OSG or Mitsubishi carbide endmills if you need extra long tools
    Does this help?
    Nots sure if its of any use, but I found this whilst researching mill types
    Quote Originally Posted by viroy View Post
    Jun 2011
    What material are you machining? Can you use a slim extended length holder vs. a really long end mill?
    Mar 2008
    454
    I am mainly cutting 6061 aluminum, but I almost always do a test cut on wood to make sure everything is accurate before going to aluminum.
    I have not seen any of the extended holders, do you know where I can look at some?
    Simon:
    That link did not work for me.
    Says the pdf is corrupt.
    Jun 2011
    What type of machine spindle do you have? Cat 40, R8, HSK?
    Jun 2011
    Check this webpage out. This product will hold tools with shank diameters up to 6mm. The holders have very slim nose diameters.
    For Micro Drills and End Mills - Mega Micro Chuck - BIG Kaiser
    Jun 2011
    For extended length metric end mills, check out Robb Jacks FM series of tools specifically for Aluminum. They have tools a little bit longer than what you are using but not much longer.
    RobbJack: Manufacturers of Premium Rotary Cutting Tools - Carbide End Mills, Saws, and Router Bits
    Arrow High Speed Spindle Motor
    We provide high speed/ frequency CNC spindle motor, power from 800W to 4.5Kw, includes air and water two cooling methods, they are mainly used for CNC engraving and cutting machine.
    If you have question or needs them, can contact with me.
    Maggie
    Arrow Stepper Motor Driver
    We provide various specification Hybrid Stepper Motor, 2 phase stepper motor, 3 phase stepper Motor, also provide matching driver.
  1. tool length offset inch to metric
    By kirby in forum Fanuc
    Last Post: 01-14-2011, 03:08 AM
  2. Small/Metric endmills
    By Magnum164 in forum Tormach Personal CNC Mill
    Last Post: 10-20-2010, 09:43 PM
  3. Pay extra for dongle, or else!
    By hecirp in forum BobCad-Cam
    Last Post: 12-30-2009, 02:59 AM
  4. Need help extra lines in dxf
    By carlnpa in forum Mach Software (ArtSoft software)
    Last Post: 03-19-2005, 10:48 PM
  5. Need Extra Long Ball End Mills (12"overall length)
    By CADkathy in forum Toolgrinding / Toolgrinding Machines
    Last Post: 02-18-2005, 04:54 AM
