603,898 active members*
4,209 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > looking for the name of a type of header
Results 1 to 8 of 8
    Smertrios Guest
    Basically its a strip of pins connected together with a piece of plastic. One side of the pin strip can be inserted into a PC board and soldered in place and the other could either get the same treatment or get pushed into a breadboard (the use I intend for it). Problem is the website I know of that useto sell them no longer does and I cant seem to find it on mouser since I dont know the right name of what I am looking for.
    neilw20 Guest
    May not be as long as you want.
    M20-9990246. - HARWIN - HEADER, STRAIGHT, 2.54MM 1ROW | element14 Australia
    Where is n/a? Bit hard to guess where is convenient for you.
    Smertrios Guest
    Thanks found it on mouser in category "Headers - Pin Strip"
    Mar 2005
    266
    So I put in my order to mouser and this is what I get for 5 pin headers... But this is just 5 individual pins off a single row header right?
    I had someone else call them and tell them about the problem and was told by the person on the phone that this is how they are sold. A "tec" got on the phone and confirmed... WTF Is there any chance that I am wrong and these really are $.08 each pins and the proper way to sell them?
    Mouser part number: 517-929834-01-01
    the datasheet linked to: http://www.mouser.com/ds/2/1/ts0769-35914.pdf
    Mar 2005
    266
    I am not saying I am wrong but even if each pin is $.08 each wouldn't having them cutup like that still be wrong? The persons on the phone insist a single row header is what I got...
    Mar 2005
    266
    My bad I was just corrected from another forum. I got exactly what I bought!
    Dec 2003
    24260
    Are you looking for a multi-pin (36) breakaway header?
    0022284363 Molex Inc | WM6536-ND | DigiKey
    They also stock dual row for IDC header.
    Al.
    Albert E.
    Mar 2005
    266
    I searched ebay and see 2 pin header BINs of interest both of which I bought. One is 3x40 pin header for $0.99 and the pic shows gold plating another is 10x40 pin header for $0.99 and shows tin colored pins.
  1. Predator header!
    By Machineit in forum BobCad-Cam
    Last Post: 06-20-2013, 04:55 PM
  2. SPI port (6 pin header) pinout
    By MetalStorm in forum CNC Machine Related Electronics
    Last Post: 03-04-2013, 11:42 PM
  3. What does this all mean in Lathe header?
    By nate in forum BobCad-Cam
    Last Post: 12-11-2012, 11:13 PM
  4. Pin out for Header
    By Mr. LocoMartin in forum Stepper Motors / Drives
    Last Post: 12-08-2009, 04:32 AM
  5. Need header tubes bent
    By RickDLance in forum Bending, Forging, Extrusion...
    Last Post: 02-16-2008, 04:57 AM
