603,365 active members*
3,712 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > Looking for a new Z axis belt for my Multicam 3000
Results 1 to 4 of 4
    The existing belt is now non-existent, it literally fell to pieces while running the machine today. So I don't have the old one to look at or measure and I cannot seem to locate any part guide for this machine. So I was wondering if anyone can help with a part number or source? It looks to be 158x10mm from my measurements, but I'm not sure what the tooth count needs to be. Also, judge from the thin "wire" I had to clean up around the pulled, I assume this belt needs to be reinforced with metal or carbon threading?
    I believe its year of manufacture is 2008 and its a 5x10 with ATC if that matters.
    Thanks, In Advance.
    Re: Looking for a new Z axis belt for my Multicam 3000
    OK, I have done some hunting online and a bunch of math.... I believe the size belt I need is 365mm and 10 mm wide with a 5mm pitch. Trade# T5-365-10 can anyone confirm?
    Aug 2009
    1573
    ...good hunting. More charts of belts/ timing type
    https://www.mcmaster.com/timing-belts
    DJ
    Just an update.
    The T5-365-10 was too big. Even with the motor adjusted all the way out on the slotted mounts there is still too much slack, but only just a hair. I just ordered a T5-355-10 which should do the trick.
  1. multicam 3000 shuddering on x axis
    By StephenSebastia in forum Multicam Machines
    Last Post: 10-08-2017, 01:36 PM
  2. 0 bond ( Multicam 3000)
    By jpfcosta in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-10-2013, 01:55 AM
  3. Multicam 3000 CNC
    By Asteriskos in forum Machinery Manuals / Brochures
    Last Post: 08-09-2013, 03:42 PM
  4. Multicam 3000 help anyone?
    By murfeedean in forum Multicam Machines
    Last Post: 05-22-2013, 05:02 PM
  5. Multicam 3000 Nightmare
    By angelocmp in forum Waterjet General Topics
    Last Post: 08-30-2007, 02:32 AM
