587,731 active members*
2,969 visitors online*
Results 1 to 6 of 6
    Feb 2006
    202
    Looking for a particular mechanism/lock
    So, I am looking for a quick release pin, such as this: http://www.halder.de/produkte/auswah...bmenu=products
    But, I need to find one that needs a key to operate. It doens't need to be high strength, just enough to prevent removal without inserting a key. Something with a shank of less than .250" should work
    Or.... instead of that mechanism, what about a lock that I could install in a small lever? (less than .625" in diameter)
    I am making a quick detach luggage rack for my motorcycle, and I would like to make it somewhat theft proof.....
    TIA
    Mar 2003
    35538
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2006
    202
    hmmm... it's a bit bigger than what I'd like, but it would work. Thanks! I will still keep looking for the "ideal" unit, but this is pretty close.....
    Dec 2006
    325
    How about a small padlock, that could do the trick.
    Best regards
    Bruno
    Feb 2006
    202
    Quote Originally Posted by brunog View Post
    Best regards
    Bruno
    Yes, that would work. If I was just looking for something for my own use, I'd go that route. Since I am hoping to one day perhaps, maybe, who knows....sell them, I need to go for a clean look.
    Dec 2006
    325
    Gearsoup,
    Check for cam locks at McMaster-Carr catalog at www.mcmaster.com this should give you an idea of what is available on the market.
    May I suggest you also take a look on how the sport racking people use their keylocks
    Best regards
    Bruno
  1. Motor drive mechanism
    By Sureform in forum CNC Wire Foam Cutter Machines
    Last Post: 07-09-2006, 06:25 PM
  2. Power DrawBar Mechanism
    By vmax549 in forum Bridgeport / Hardinge Mills
    Last Post: 11-19-2005, 12:10 AM
  3. Sources for Lead Nut Mechanism
    By space_case in forum Linear and Rotary Motion
    Last Post: 04-22-2005, 01:58 AM
  4. Digital Stop Mechanism
    By polyhedron12 in forum Community Club House
    Last Post: 02-21-2005, 03:54 AM
  5. lead screw mechanism
    By sp00k1e in forum DIY CNC Router Table Machines
    Last Post: 02-10-2004, 12:14 AM
