588,195 active members*
4,937 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Looking for some "high"er speed spindle ideas for my bf20 clone
Results 1 to 15 of 15
    Hey guys, Ive been starving for some more rpms. I typically use 1/4" endmills for my little aluminum projects, but 2400rpms isn't enough.
    I've read the stock bearings can handle 3800 if you gear it? That may be the easiest option.
    However I am curious about two others, can any one give me any info on using the stock motor and speed controller for a new high speed spindle set up. If I built my own milling head and spindle, then geared the stock motor to drive a spindle at 6000rpm for example, would and could the speed controller/motor handle that?
    Second idea, variable speed 1/4-1/2" router. While I see most sit around 8-16k rpms, can any one comment on the life span of a router being used to machine aluminum?
    I should mention I'm not really in the market for engraving, I just want to drive my 1/8-1/4 endmills a little closer to their proper speeds in aluminum.
    Thank you so much.
    You'll find a few ideas here, from gear mods to belt drives.
    http://www.g0704.com/Projects.html
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    May 2005
    3920
    There are many options, research is your friend.
    Quote Originally Posted by GreatNorthGnome View Post
    One thing to consider with gearing is noise which might become excessive at high speed. Wear is another issue. Personally I'd consider a belt drive or direct drive spindle.
    As to bearings and speed don't take some bodies word for it. Hit the web and look up manufactures data for the bearings in question. Top speeds vary widely based on a large number of factors. The other thing is that many of these mills come with less than optimal bearings for the task at hand.
    That is a bit of a loaded question. How hard do you want to drive the mill? Is this a CNC mill? Your best bet here is to do some research with a good speed and feed calculator. You should be able to determin horsepower requirements with a little bit of estimation.
    Again a loaded question. The big problem with most routers is their open design with the high likely hood of pulling in metal leading to an early failure. High speed router though often need rebuilding simply due bearing wear even if routing wood. It is a cheap solution though even if you toss a router from time to time.
    Thank you so much.
    This is a big problem on these low cost mills, thus you can find hundreds of different approaches to high speed spindles on the Internet. Your course of action depends upon how much use you actually only need this capability. By that I mean if you never run steel or other hard materials then maybe a more dramatic overhaul would be in order.
    If you are sure that aluminum will be the only material cut then it might make sense to build a new spindle with high speed capability. Maybe something with an ER collet and a direct drive motor.
    I get the sense though that you want to do this cheap, mainly because of the questions about reusing the old motor and controls. Your best bet here is probably some sort of belt drive upgrade with new bearings in the spindle you already have. I'm not sure if the RPM gains would be worth it though. Say you hit 4000 RPMs, would that be enough for how you intend to use an 1/8" end mill?
    Jan 2010
    151
    +1 on hoss's project page, he's been the innovator of many of the upgrades and has done all the research and testing for you.
    am
    Sorry for the delay, things have just been a little busy lately.
    Thank you for the responses and ideas, this gives me some possibilities to look into.
    So here is my solution for now, however I hit a bit of a speed bump.
    It was supposed to be a 1:1.16 ratio, however the one pulley wouldnt clear a couple things. So I had to reverse it and run 1.16:1.
    So I can get upwards of 4600rpm, but I'll keep it below 4k.
    Now I knew it would reverse my spindle rotation, but apparently I've never used reverse on this machine. Why does my machine only run like half rpms in reverse? I just read that this is a common thing on these bf20's? That's unusual so hopefully I can just reverse the motor wires and run the forward option. I ran out of time tonight to try it out.
    Dec 2003
    24220
    Albert E.
    Dec 2003
    24220
    It is a DC brushed motor so just swap the motor leads.
    Al.
    Albert E.
    Thanks Al, It is working great now. The extra rpms have made a huge improvement, reduced chip load and the cutter ejects the chips alot easier.
    Jun 2011
    Very, Very Nice innovative approach to the belt drive.
    Eoin
    Thank you! Its not as pretty as I wanted, but it works so who cares
    I noticed a minor loss in torque which is to be expected, but nothing severe.
    Dec 2013
    11
    Re: Looking for some "high"er speed spindle ideas for my bf20 clone
    Sorry for posting on an old thread but I wanted to show you how I have handled this higher RPM problem. My motor says it is rated for 5600RPM and so I have cranked up the pot to go to 4k on the main spindle. I did not want to push the spindle bearings because I am unsure what they are rated to.
    Attachment 238992
    The main reason I have made this bracket to hold it is so I do not make any modifications to the mill and therefore do not invalidate the warranty. I have a good 11 months left on her yet! It would have been much easier just to drill and tap it straight to the head.
    It uses 2 of the 6mm threads holding the top of the head down(it is still keeping the head together, just sandwiching the bracket now), the 8mm thread for the spindle lock (while the secondary is attached I lose the spindle lock option) and the 2 5mm threads that used to be holding the safety guard on.
    So far it has worked very nicely!
    Nov 2009
    4415
    So this is running the extended rpm through the original gear train H/L? I cant imagine how long the plastic gears will last. How is the noise?
    A lazy man does it twice.
    Dec 2013
    11
    Quote Originally Posted by Fastest1 View Post
    The primary spindle has its extended RPM running through the original gear train but I rarely push it past 3500RPM because I do not know how it might adversely affect those other bits I don't know about. So the spindle bearings and the gearing. I know the motor is fine for up to 5600RPM. It has been fine so far. Do you think that too much of a push for it?
    The 24K is coming from the spindle motor mounted to the side.
    I AM GLAD TO TAKE THIS OPPORTUNITY TO INTRODUCE OURSELVES AS ONE OF THE LEADING SUPPLIERS OF Precision Bearings for CNC and Machine tool ,AND YRT bearings WHICH ARE FROM THE REOWNED MAKE OF Wafangdian Tianjiu Bearings Technology Co.,Ltd.,.
    WE ARE IN THIS BUSINESS SINCE LAST FIFTEEN YEARS; IN THIS SPAN OF TIME WE HAVE SUPPLIED PRECISION IN ALMOST ALL THE CONTINENTS OF THE WORLD.
    OUR BEARINGS WITH COMMON PRECISION ARE MAINLY MIDDLE / LARGE BALL BEARINGS, ROLLER BEARINGS AND SELF-LUBRICATING JOINT BEARINGS. OUR SL BEARINGS ARE FAVORED BY CUSTOMERS. BESIDES, WE DEVELOP HIGH-PRECISION YRT ROTATED BEARINGS, MACHINE TOOL MAINSHAFT BEARINGS AND MOTOR PRECISION BEARINGS. THE PRECISIONS OF OUR BEARINGS HAVE REACHED LEVELS OF P5, SP, P4 AND UP.
    FEATURED BY HIGH PRECISION, LOW NOISE, HIGH ROTARY SPEED, HIGH QUALITY AND LONG SERVICE LIFE, OUR PRODUCTS SAVE USERS’ COST AND SHORTEN PURCHASE TERM. WIDELY APPLIED TO COMMON MACHINE TOOLS, CNC MACHINE TOOLS, LARGE / MIDDLE MOTORS, PRECISION ROLLING MILLS, ETC., OUR PRODUCTS FILLED THE DOMESTIC BLANKS AND CAN SUBSTITUTE IMPORTED PRODUCTS.
    THIS IS TO INFORM YOU THAT WE HAVE PRECISION BEARINGS AND OTHER GOOD QUALITY BEARINGS AVAILABLE, CAN SUPPLY FOR YOU WITH BEST QUALITY.
    PLEASE SEND US YOUR REQUIREMENTS IF YOU HAVE BEARINGS NEED.
    WE CAN SUPPLY OUR BEST PRODUCTS FOR YOU.
    (Wafangdian Heavy Bearings Researching & Manufacturing Co.,Ltd.)
    Brand:WZFB
    Web: 瓦房店天久轴承科技有限公司(原 瓦房店重型轴承研究制造有限公司)
    Tel: 0411-85366785
    Fax: 0411-85366785
    Mobile:+86-15942617721
    E-mail:[email protected]
    Q Q : 178702120
    Skype: lixingwen1987
    Do our best to give customer best service.
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. "X" axis ballscrew locking up at high speed
    By Barefootboy4 in forum Linear and Rotary Motion
    Last Post: 07-19-2011, 07:55 PM
  3. "high" speed spindle with cad model
    By Thorpydo in forum Benchtop Machines
    Last Post: 04-21-2009, 11:38 PM
  4. My "Crazy" high speed spindle test
    By SScnc in forum Benchtop Machines
    Last Post: 04-21-2009, 01:16 PM
