587,693 active members*
3,615 visitors online*
Results 1 to 18 of 18
    Jul 2007
    13
    looking for some materials
    hey this is probly in the wrong section, i couldnt figure out with would fit best.
    but anyways can anyone recommend a spot to get some steel ive searched and im not coming up with much i need
    4340 and 1050 steel billets
    TIA!
    Apr 2007
    148
    Quote Originally Posted by ebydrc View Post
    TIA!
    Try McMasterCarr, they have quite an assortment of materials. If you need bulk they are a little on the expensive side. We use them as I can get what I need the next day, for me getting my stock quickly is more important than saving a few bucks, and we don't need large amounts of stock. Hope this helps.
    onlinemetals.com, speedymetals.com for hobby sized stuff
    Jul 2007
    13
    Quote Originally Posted by JDenyer232 View Post
    they didnt have any 4340
    Jul 2007
    13
    Quote Originally Posted by will gilmore View Post
    tried both those i need some larger billets, im starting to think im going to have to start calling forge company and seeing what they are able to offer for the steel, im afraid they are going to want alot of $$$
    Mar 2006
    2712
    What size is "bigger"?
    Dick Z
    DZASTR
    Jan 2006
    2985
    Look in the yellow pages for industrial supply, steel supply, etc. There are at least 6 suppliers in the town I work in, all having huge warehouses full of steel. Where are you located?
    Matt
    Jul 2007
    13
    Quote Originally Posted by keebler303 View Post
    Matt
    mountain home, ar
    Jul 2007
    13
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    flats like, 1.5" x 4" x 6"
    Nov 2007
    154
    laser fonts
    Has anyone purchased software called CAD-KAS FONT 2 DXF is it worth the money? Needing to find a software that can do letting for lasers, that has the letters split into or a stencil format.
    Jan 2006
    2985
    Alro Steel has warehouses in Tulsa and St. Louis. I buy most of my stock through them.
    www.alro.com
    If that doesn't work out, you could contact Nessteel. They specialize in tool and alloy steels and ship all over the US. Shipping might be more expensive since they are in CT, but they could probably get you what you need.
    http://www.nessteel.com/
    Matt
    Mar 2006
    2712
    It might be less expensive to purchase drop-offs from round bars and mill it to size. Many alloys are available in hot rolled rounds only.
    Dick Z
    DZASTR
    Jan 2006
    2985
    If that is the case then onlinemetals has round bar of the appropriate size.
    linky
    $260
    Matt
    Jul 2007
    13
    linky
    $260
    Matt
    yeah exactly way to much, has anyone worked with forging company or have a recommendation for one, i have no idea about that stuff or the right companies to deal with i need those sized billets i said earlier, in small quanities like under 20 pieces a month.
    If you plan on doing close to 20/month you can get a 20' bar and have two months worth.
    I wanted some 19 gauge CR steel sheet and my usual place laughed at me. I found a place called Windustrial and they got some and delivered me 5 4'x8' sheets. I looked and there is one in KC.
    Jan 2005
    15362
    Hi ebydrc On doing that much a month you should be able to get some good pricing
    I use Nessteel they have may have what you need
    http://www.pennsylvaniasteel.com/flexor.php
    Mactec54
  17. #17
    Jul 2007
    13
    ill have to talk to them about a year ago i talked with a forginf company, they wanted a 100 unit first off and a large fee to start a run, the rep i talked to said that was industry standard, i never checked other companies to see if there was any truth to the statement, at that point i was thinking about a new business venture, now. however id really like to pull the trigger and figure out where and what i need to do to get the material
  18. #18
    Jul 2007
    13
    that number is projected, oviously i would love to see atleast 50+ a month but with the current state of economy its hard to tell.
    any exp. with that flexor?
  1. Where to buy materials?
    By Chevy-SS in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2023, 10:20 AM
  2. Materials
    By david90 in forum DIY CNC Router Table Machines
    Last Post: 11-14-2007, 08:55 PM
  3. materials
    By ironDigit in forum Material Machining Solutions
    Last Post: 06-24-2006, 02:43 PM
  4. Materials
    By ryanduc in forum Uncategorised MetalWorking Machines
    Last Post: 10-09-2004, 07:12 PM
  5. materials
    By broncosis in forum DIY CNC Router Table Machines
    Last Post: 06-13-2004, 01:23 AM
