Here's a video working off the points you specified in the .pdf. A couple of things are worth mentioning. I chose to use flat bulkheads fore and aft, but it would work exactly the same if I'd drawn arcs instead of lines, and thus revolved nose and tail cones instead of bulkheads. Toward the end of the video, I'm messing with the viewing angles, trying to see things. A much better way of doing things is to use layers, and keep things like the base geometry and the surfaces / solids separated. I just didn't want to confuse things or make the video any longer, so you get to watch me swing the camera around, instead. ![Smile](images/smilies/smile.png)
This video felt more crowded than the other one. I hope it's not too hurried or disjointed.
Luke
"All I'm trying to find out is the fellow's name on first base" -- Lou Costello
