587,143 active members*
3,120 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Looking for stepper motor control system for a single axis
    Nov 2017
    7
    Hello!
    I am looking for a motor driver for a 24 volt motor (likely a 2315HS300AW-OB) - I'll probably use a KL-5056E as I've always had excellent results with those.
    The thing I really need help with is a motion controller. I am using this system for a very specific application where I'm only moving a single, linear axis back and forth over about a meter distance. Eventually, I'll likely write some software myself to perform the motion but in the meantime I need both some sort of motion controller board as well as software to execute the commands. I hate the idea of buying a 3, 4 or 6 axis controller board along with something like Mach 3 or 4 just to control a single stepper motor. Do you happen to have any ideas as to what I might be able to use to perform some simple, yet accurate linear motion?
    Thanks in advance for any help you can provide!
    Thanks,
    Marshall
    Apr 2020
    50
    Re: Looking for stepper motor control system for a single axis
    Hi Marshall
    I will make the assumption that you are making a camera slider or auto feed for something..
    I have made 555 circuits to drive a manual feed with direction switch and variable speed.
    On Aliexpress you will find cheep stepper motor test boards.
    The stepper motor drivers only need 2 signals to opperate;
    1. Direction, high or low signal
    2. Pulse to move
    You can use a simple 555 timer circuit configured as square wave generator to drive the Pulse input on the Stepper Driver.
    You can also add a cheap rotary encoder for manual control.
    do a google for 555 stepper motor driver or ask at a local electronics store for 555 Timer/Frequancy generator kit should be sub $10
  1. Single axis stepper control setup
    By harryn in forum Gecko Drives
    Last Post: 05-01-2018, 04:40 AM
  2. 4.5A THB6064AH Single Axis Stepper Motor Driver Review
    By tinky1233 in forum Stepper Motors / Drives
    Last Post: 09-12-2017, 03:10 PM
  3. analog control for a single axis stepper
    By cstmwrks in forum Mechanical Calculations/Engineering Design
    Last Post: 04-23-2014, 03:04 AM
  4. Replies: 1
    Last Post: 08-04-2013, 01:53 PM
  5. 3 axis stepper motor driver using a single PIC
    By david90 in forum PIC Programing / Design
    Last Post: 04-06-2008, 03:22 AM
