587,188 active members*
4,262 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Looking for turn key bench top engraver
    Mar 2006
    21
    I am looking for a turn key bench top engraver or mill (X14" x Y8" x Z3" travel?)for engraving text in small 1" dia. ceramic(green) discs. I am experienced with G code and already have software to generate code. I would prefer it to have its own controller. The unit will be operated by two old guys (one is my dad) that have problem with there VCR! The machine will bet set up with vacuum plate for as many parts the travel will allow. They can be shown how to load the files or select one already loaded in the machine set there Z and maybe away they go! I was hoping to get away from a having a PC but if it can be kept simple it is an option. Any suggestion or followup questions would be appricated!
    Dave
    Aug 2006
    33
    Turnkey engraving machine
    Quote Originally Posted by xyzer View Post
    Dave
    Please, visit the following web address:
    http://www.solustan.com/products/MicroSmartEngraving
    You should see three different turnkey engraving machines. They are available with USB 2.0 connection. Designer can generate a job in AutoCAD 2005 or Corel Draw version 9 or higher, DolphinCAD, or AcceliCAD and generate M&G codes. The file can be made available to your dad for downloading it to the machine. All he would need to do would be to set up the surface of the material and depth of cut. The smallest one is $6,999.
  1. EMCO PC TURN 50 Bench Top Retrofit
    By remcb in forum Vertical Mill, Lathe Project Log
    Last Post: 01-16-2009, 02:12 AM
  2. New bench for a new SX3
    By Involute in forum Syil Products
    Last Post: 06-16-2007, 01:12 AM
  3. Steel bench for X3
    By keen in forum Syil Products
    Last Post: 04-19-2007, 07:47 PM
  4. mill/turn on a cin turn
    By Robert Timby in forum Uncategorised MetalWorking Machines
    Last Post: 02-01-2007, 05:33 AM
  5. Cin Turn turn/mill
    By Robert Timby in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2007, 02:12 AM
