603,311 active members*
4,144 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Looking for zero backlash ballscrews
Results 1 to 9 of 9
    Jul 2007
    11
    I have heard that CandGResearch was the place to get them, website is down and Dan Mauch has advised that Chuck McGhee had moved east and his shop is not yet setup.
    Any other recommendations?
    Thanks all
    Gary
    Dec 2005
    93
    Dec 2005
    3319
    HIWIN makes some real jewelry when it comes to precision ground remove and replace ball screws for various milling machines - surely, they can be adapted to various other applications.
    When you use ture, high preload, ball screw support bearings, the axial accuracies and backlash values can be deadly accurate.
    Jun 2005
    232
    Hello Gary I don't know what size ballscrew you need .I have a pallet of mostly double nut preloaded ball screws I need to get rid of. They came from a plant that makes carbide end mills.These are used and they came off of there cnc grinders . They may not be good for a cnc grinder but I think they are perfect for a cnc router or small milling machine. They take the screws out of there machines after a certian number of hours before they have problems with them.So they still feel smothe and tight. Most of them are 33 inchs long 22 inchs of travel 25 mm dia and 10mm leed. If you live close to greenville SC you can come look at them in person .I would like to sell them for $30 each plus shipping.
    Tim Kallam
    Attached Thumbnails Attached Thumbnails pallet ball screws.jpg   ball screws.jpg
    Tim
    Nov 2006
    G'Day Tim.
    Just a quick enquiry.
    What are the diameters of the rods, and what TPI?
    I live in Melbourne Australia, and things are pretty pricey here.
    What would shipping for 2x 800mm unit be?
    Rob.
    Jul 2007
    11
    I originally posted this in the Shoptask machine forum as I need screws that will fit the Shoptask Eldorado Bridgemill (Version prior to the newer Tripower).
    Moderator saw fit to move the post here and begin this thread.
    CandGResearch used to make sets specific to this machine but I have heard that Chuck has moved east and not setup his shop as yet.
    I am looking for a bolt on set and would have no ideay hoe to go about ordering a set from the recommended site that would not need modification.
    Any help is appreciated.
    Gary
    May 2007
    Dear Tim
    Is your thread about ballscrews still up to date ?
    In case how can I reach you ?
    Greetings Bert
    Feb 2007
    3
    ball screws for sale?
    Im interested in buying some of your ball screws as well. I sent you a PM. Let me know if these are still available (adi_orio at hotmail dot com)
    Aug 2007
    57
    would you ship to canada ?
  1. Servo idea - elimated backlash - zero backlash !
    By synthetiklone in forum Linear and Rotary Motion
    Last Post: 12-06-2006, 08:35 PM
  2. NSK USA Ballscrews
    By Ketchak in forum Linear and Rotary Motion
    Last Post: 10-23-2006, 03:38 AM
  3. why ballscrews???
    By 50062040 in forum Linear and Rotary Motion
    Last Post: 01-19-2006, 05:42 PM
  4. McMaster Carr ballscrews- improving backlash
    By walter in forum DIY CNC Router Table Machines
    Last Post: 08-03-2005, 12:26 AM
  5. Ballscrews & Backlash
    By rustyolddo in forum Benchtop Machines
    Last Post: 05-13-2005, 07:42 PM
