I thought I was about done with my R2E3 retrofit project. But, doing some testing, I found it was losing a little bit of position when moving. Every axis shows this, but it is worst on the Y axis. I have a program that moves Y 3" back and then returns to the indicator. It seems like at 12IPM or below, it doesn't seem to lose position, but above that speed it loses from a half to a full thousandth on each repeat. I've looked at the A and B quadrature signals with a scope, and they look good, the differential complements look like complements. I am using my own CNC interface that is a manufactured product, and I've never seen this on my older Bridgeport using the same hardware.
This retrofit is using the Pico Systems PPMC interface, LinuxCNC, and AMC 30A20AC servo amps, and the original motors. I reterminated the original Bridgeport encoder cables to the PPMC encoder board, and have checked all that wiring.
Anybody have any suggestions? I'm strongly considering replacing all the encoders, there are some nice ones on eBay right now, but I would have to make shaft and mounting adapters.
Thanks for any comments,
Jon
