Losing steps
I am having trouble with my mill, it seems that I am losing steps. The mill is set up as follows...
1986 Hurco SM1 Stock ElectroCraft Servos and encoders, Larkin Viper 200 drives, Smoothstepper, CNC4PC C23 BOB, Dura Pulse GS3 VFD, Mach 3
I am using an indicator mounted in the spindle, I zero out the indicator on a bar clamped to the table parallel to the Y axis. I then make a G1 move in the X axis of -1.000" and then insert a 1" Jo block. With the feed rate set to 4 IPM the indicator reads .000. I then rezero my indicator on the Jo block, remove the block and make a g1 move in the X axis back to 0. The indicator will read -.0015. I did this 3 time at this feed rate and had the same results. When I increase the feed rate to 6 IPM, I get an indicator reading of .001 on th first negative X axis move, but it is off -.035" on the move back to 0. If I increase the feedrate to 10 IPM I get .006" on the negative move and .067" on the move back to 0. If I do a G0 move it is off almost .185" on the move back to 0, sometimes the axis will error(red light flashing)on the G0 move.
I've done some testing in the Y and Z axis and don't seem to have any issue, the indicator reads within .0005" both directions.
Any idea what might be happening?
Tom
