588,444 active members*
5,140 visitors online*
    Nov 2009
    5
    Losing steps in Z axis!!
    Hi all,
    I'm new to cnc machining although a machinist by trade. I have a pro built aluminium cnc mill which appears to be working fine except I appear to be losing steps in Z axis. I can engrave a few letters and the tool is climbing away from the material. after a few minutes of running the Z axis has crept away from the material about half a millimeter. I have checked the security of the toothed belt drive and pulleys all ok and the tool is not slipping in the chuck. My only idea now is a faulty controller card, could this be the problem? Does anyone have any other ideas? Help would be most appreciated! The error is consistant across all types of engraving.
    Regards, Gwyn
    Sep 2009
    is your axis moving up n down for every engraving,if so check backlash given in the ball screw or the endbearing locking.
    Apr 2009
    134
    Are you using mach3?
    I had similar problem,the solution was setting dir puls in motor configuration to 5us.
  1. Y Axis losing steps
    By justgary in forum Tormach Personal CNC Mill
    Last Post: 01-16-2009, 08:14 PM
  2. Losing steps with the Y axis
    By norman roy in forum Tormach Personal CNC Mill
    Last Post: 12-23-2008, 03:29 AM
  3. Bridgeport series 1 Losing lots of steps on Y-axis
    By bartL in forum Bridgeport / Hardinge Mills
    Last Post: 10-07-2008, 06:02 PM
  4. Y Axis keeps losing Steps
    By Normsthename in forum DIY CNC Router Table Machines
    Last Post: 11-06-2006, 12:26 AM
  5. HobbyCNC board Z-axis losing steps
    By raiven in forum Stepper Motors / Drives
    Last Post: 07-06-2005, 08:53 PM
