603,932 active members*
2,351 visitors online*
IndustryArena Forum > MetalWorking > Casting Metals > lost foam casting ??
Page 1 of 2 12
Results 1 to 20 of 23
Hybrid View
max_imum2000 lost foam casting ?? 10-13-2006, 02:21 AM
Redline This may sound stupid,but I... 10-13-2006, 07:27 PM
max_imum2000 thanks for your advice... 10-13-2006, 11:09 PM
Redline I mix it at about an 80 / 20... 10-14-2006, 01:52 AM
Splint Give some thaught to using... 10-15-2006, 01:32 AM
tool_man I have read a lot on the... 10-18-2006, 03:48 PM
appicnc Hello Group I use the... 10-30-2006, 04:06 AM
orjan_nilsson Herr Warum 12-04-2006, 10:41 PM
CJL5585 Lost Foam Casting using... 12-05-2006, 12:56 AM
CJL5585 Lost Foam Casting using... 12-05-2006, 12:58 AM
appicnc Plaster Types 12-05-2006, 06:12 AM
JerryFlyGuy Anyone tried mixing some... 12-05-2006, 02:38 PM
wtxrcdog Hello I have made a few... 01-02-2007, 04:49 PM
wtxrcdog lost foam 01-02-2007, 05:01 PM
hilldude I use pink foam from home... 02-23-2007, 04:40 AM
wtxrcdog lost foam 02-23-2007, 05:57 AM
The AAtrain Yeah- this works well, we use... 03-16-2007, 03:20 AM
Mitsui Seiki Have you guys tried the lost... 02-25-2007, 10:29 AM
wtxrcdog lost wax 02-25-2007, 01:12 PM
max_imum2000 Mitsui Sieki nice production... 02-25-2007, 01:21 PM
Mitsui Seiki I'll find out and let you... 02-25-2007, 01:24 PM
max_imum2000 :) thank you i will be... 02-26-2007, 12:37 AM
The AAtrain I have had good success using... 03-16-2007, 03:14 AM
    Sep 2005
    167
    i was reading about this process, each time i see that it should be dipped in a ceramic slurry and then dried .
    i need to ask what is the ceramic slurry compostion, and how can i make it dry well.
    does the final parts require machining ? and what level of machining?
    thanks
    Oct 2004
    85
    This may sound stupid,but I use drywall compound mixed with a little furnace cement. I thin it with water till it's like a melting milk shake.You only want to coat the part about 1/16 thick or so. If your part has little nooks and crannies you may want to paint it on with a brush.
    :cheers:
    It turns out just as smooth as the finish of the foam.The better the finish is on the foam the better the part will look. Foam is easier to work than aluminum so take your time on the foam plug and your finished part will require little to no machining.
    Sep 2005
    167
    actually if it works then its not stupid at all
    but do you bake the mixture after you apply it ? or you just let it down to set ?
    if you bake it , what temp and duration do you use ?
    what mixture composition for cement and compund ?
    thanks
    Oct 2004
    85
    I mix it at about an 80 / 20 mix. 80 drywall compound 20 furnace cement. I just let it air dry for a few days.
    Jun 2003
    451
    Give some thaught to using plaster of paris, I've not used it myself but I think it would work ok and it's cheap.
    Feb 2006
    83
    I have read a lot on the internet about lost foam casting. although I have not used the process myself,most everyone is thinning drywall compound and brushing on a thin layer.Let it dry.Do not bake,it will damage the foam.This is the first time I have heard of mixing furnace cement with the drywall compound.Interesting.May have to try that.
    Aug 2005
    78
    Hello Group
    I use the following process generally with good results, after the part is cut in foam dip into a 20Ltr container of water with small amount of detergent added, this " wets " the surface of the foam and stops small air pockets forming when dipped into plaster, let drain until free water has drained off ( < 30 secs ) then dip into what we in Australia call " finishing cement " ( used as the top coat in gyprock plaster, air dries )
    Set aside until dry then either re-coat or use, drying time varies with season now it's Spring I cut a part at 6:00pm yesterday, dipped twice < 10:00pm and cast this morning ) winter it takes two days ( or more ) per coat.
    I tried plaster of paris with unuseable results ( the moisture in the mix reacts with the Al - don't waste your time with any chemical reaction setting plasters )
    Ed
    Jul 2005
    10
    Wink Herr Warum
    G'day fellow metal hobbyists.
    I've been experimenting with lost foam alu-casting for some time now. My main concern is getting a consistent result. Have tried a lot of different shells for foam patterns.
    One of the problems is getting the ceramic slurry to stick to the pattern. Thanks appicnc for providing me with a simple solution(thats why I'am posting this). Without lowering surface tension, the slurry is slipping of the pattern. Even droplets of water is sliding of the surface. Anybody have an explanation for this? I'am cutting the foam in my homemade CNC-router.
    Tried dry wall mixture, but had some difficulties. After drying foam+coat in oven(with PC-fan circulating the air!) and investing(is this the right term?) into dry loose sand, the casting has some micro bubbles. Shell is hard after drying but crumbles after heating to pouring temp for some time. (gypsum or other lowtemp binder?).
    My next step on the learning curve was discovering that ceramic slurry=mud!. OK, the ceramic slurry for high production industry is tailored to ...hm... high production industry. Stiring the slurry tank 24/7 and so on.
    Here in Sweden, an old tech for insulating houses is draping the wood with a mixture of clay and straw. This tech is having an renaissance as insulation in houses(by the way, anybody seen large amounts of polystyrene burning?) So I tried this Lermjöl/Clayflour. I think it has about the right properties. Low shrinkage, dirt cheap:-), fire proof, follows contour. What is lacking is porosity for letting gases out, and when diluted to much in water it has a tendency to crack. Stucco with silica sand solves the problem.
    Now to my question:
    What will happend to industry ceramic slurry if not ”dipped” in Stucco? Just building layer after layer of slurry.
    (Sorry about the lengthly post, but I didn't have time to compress the information further, and compressing it further would have made it incomprehendable)
    Oct 2004
    742
    Lost Foam Casting using Drywall compound
    http://www.buildyouridea.com
    Has everything step by step.
    Oct 2004
    742
    Cannot get link to work at this time.
    EDIT: Had extra character in web address. It works.
    Aug 2005
    78
    Plaster Types
    Hello Group
    I don't think the type of plaster used makes a great deal of difference, I think it the primary reason to use plaster is to provide a smooth finish by keeping the sand off the part, the sand generally being courser ( sp ) than the plaster, all of the makes on the cast part were on the foam pattern except the " pimple " at the 7:00 o'clock position under the six, I have had the plaster break, as in the third photo ( along the end closest to the camera ) but this part was cast vertically and the end was down, now when doing that type I would use maybe three coats but more importantly, I would shake and tamp the container holding the part so the sand was more firmly packed around the part.
    I haven't used vents on the parts because I use a big sprule so the gas can escape as the metal is being poured in, the vent would need to be clear so the gas can escape which would mean being careful with the part in the sand and clearing the vent, large sprules seem to work ( for me )
    The only plaster I would say away from is the type that sets by a chemical reaction - like casting plaster, I tried that to start with and despite drying for days ALLWAYS had failures, the air drying plaster works - again for me.
    The " 168 " was cut by a router in dense blue foam, the linear bearing holder was cnc'd hot wire cut.
    The last photo is of the ( unfinished ) machine, as can just be seen the burst plaster didn't affect he bearing, just behind the router, the Z axis slide was also cnc hot wire cut blue foam.
    Ed
    Attached Thumbnails Attached Thumbnails DSCF0017.jpg   DSCF0027.jpg   DSCF0907.jpg   DSCF8328.jpg
    Sep 2005
    1660
    Anyone tried mixing some silica powder w/ the plaster? Something like Cabosil? I wonder if a person mixed the plaster thin then thickened it back up w/ this if it wouldn't stand up a bit better? or is this simply overkill?
    Jerry [not casting, yet ]
    JerryFlyGuy
    The more I know... the more I realize I don't
    Dec 2004
    48
    Hello I have made a few lost foam castings with some success. I used drywall textureing compound. The first try failed because the plaster cracked due to not having enough sand packed around the mold. the second one was usable.
    Dec 2004
    48
    lost foam
    Here are some pics of my attempts.
    Attached Thumbnails Attached Thumbnails patterns.jpg   secondtry1.jpg   molds1.jpg
    Feb 2007
    3
    I use pink foam from home depot diped in dry wall mud. mix very thin almost like laytex paint.let dry cover with sand. need about a four in riser 1in sq.Start pouring and dont stop untill it overflows.Dry wall is only to keep sand from metal.If drywall compound is to thick takes longer to dry
    Dec 2004
    48
    lost foam
    Hello
    I just thought I would tell you guys about a cool way to cast with foam and believe it or not masking tape! If you are not worried about the finish tape is a lot quicker than the plaster deal. what it amounts to is what ever the tape looks like on the outside is what you get. you do every thing else the same.
    If you are going to machine your parts anyway this is the way to go. as soon as I remember how to put photos up here I will post some pics of a linear bearing we are making.
    Later Bruce
  17. #17
    Quote Originally Posted by wtxrcdog View Post
    Hello
    Later Bruce
    Yeah- this works well, we use masking tape on our joints to keep sand out (when packing in dry brick sand w/ no coating)
  18. #18
    Feb 2007
    464
    Have you guys tried the lost wax method?
    My company use that and it is probably the best way if you want close tolerances.
    http://www.tpcab.se/
    Go for Production and then Production Info.
    I'm in there somewhere in front of my Mitsui Seiki
  19. #19
    Dec 2004
    48
    lost wax
    Hello
    I have tried lost wax investment casting. I used to make jewelery out of silver
    and this method works very well. For the parts I am making now I would need another furnace for burn out as well as one for melting the metal. I am sure this method is better than lost foam just more steps and more equipment.
    Bruce
  20. #20
    Sep 2005
    167
    Mitsui Sieki
    nice production
    but whats the composition of the ceramic slurry ur using ?
Page 1 of 2 12
