603,982 active members*
2,505 visitors online*
Results 1 to 8 of 8
    Dec 2008
    6
    Cool Lost parameters
    Hello, I have a CNC OKUMA & HOWA Machine model Millac5va, this machine use the Control Fanuc 11M, by mistake the operator of this machine erase all the parameters, How can a get a list of this parameters to input to the machine again? Thanks
    Jan 2008
    575
    I would send a personal message to Appsman he can probably help
    Robert
    Dec 2008
    6
    Thanks, for your support
    Dec 2008
    6
    Hello:
    As I mentioned before I lost my parameters in My machine, I find that in the maintenance manual for Fanuc Control 11M (B-54815E/03) there's a parameters section, somebody know if in this seccion are a list of the parameters? I ask because I would like to buy this manual if the list of parameters are there. Thanks.
    Dec 2008
    3216
    A word of advice
    Unless the parameter section in the manual is a hardcopy of your machine and your serial number is stated, I would assume it only to be a sample or basic listing for all machines, not just yours.
    IMHO, I would NOT use it.
    Check inside all cabinets, as there should be a data package for that specific machine ( it should contain machine build specifications, purchased options and test reports. Possibly wiring, plc diagrams, etc. you may be lucky and find a set of floppies or CD with your initial set-up parameters)
    Your machine manufacturer will also have these as they are specific to the serial number
    It would be in your best interest to go to each of your machines and take a copy of it's parameters and backup onto CD and file offsite ( copy everything-more is better than just a little-the bit you need now is the bit you thought you'll never need ).
    Happy Hunting
    Dec 2008
    6
    Thanks Superman. I already talk to okuma howa and I gave them the serial number to get a copy of the original parameters of the machine.
    Dec 2008
    6
    Finally I got the parameters list for a Millavc5va control Fanuc 11M and 15M, if somebody need it just let me know and I will forward. Thanks everybody.
    Dec 2008
    if there is no back up with the machine (in electric cabinets and the like) then i would get in touch with okuma for replacement as each machine is different and they will need the serial number. they should have backup for each machine, thats what we do (i work in apps)
  1. Lost parameters
    By darrylh in forum Fanuc
    Last Post: 06-09-2010, 08:02 PM
  2. Parameters lost in Fanuc OM
    By wicked_won in forum CNC Machining Centers
    Last Post: 03-27-2008, 10:50 PM
  3. OKK Parameters lost!!!!
    By Fidelity_Mold in forum Uncategorised MetalWorking Machines
    Last Post: 08-01-2007, 08:20 PM
  4. Lost parameters on 10T
    By ktb100 in forum Fanuc
    Last Post: 03-29-2007, 06:38 PM
  5. HELP...interact 4 lost parameters
    By camarogod98 in forum Bridgeport / Hardinge Mills
    Last Post: 02-13-2007, 01:50 AM
