603,848 active members*
3,695 visitors online*
    Feb 2013
    16
    Loud noise on slow feed?
    Just got my moving gantry CNC up and running and I'm just fiddling with the program and jogging the machine. Is the machine supposed to make a slightly screeching, somewhat loud noise when it runs slowly (approx. 10in/min)? For example, when running the roadrunner, the machine sounds slightly "scratchy" during the small segments.
    Dec 2004
    783
    Steppers can make all sorts of noise and it can resonate through the machine at certain feedrates. If your not losing steps and the cut looks good, don't worry about the noise.
    Sent from tapatalk
  1. Loud noise when laser comes out of datum position
    By BuckeyenNJ in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-29-2022, 02:58 AM
  2. Slow motion and harsh noise
    By Marcin81 in forum DNC Problems and Solutions
    Last Post: 05-24-2011, 12:23 AM
  3. Feed rate slow down
    By gtdinc in forum Fanuc
    Last Post: 04-30-2011, 11:49 AM
  4. Replies: 1
    Last Post: 03-16-2011, 04:43 PM
  5. Bridgeport Boss 4 loud noise in head. It is alive...
    By gschoep in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 03:44 AM
