603,967 active members*
1,918 visitors online*
    Sep 2007
    300
    low following error not a good thing?
    I just tuned a servo system and ended up with a following error that was sub tenth thousanths. A friend made this statement :
    "How come Fagor CNC controls recommends following error to be .100?
    They state the machine should lag the control. I forget why following error shouldn't be so tight."
    I find it hard to believe that fagor would state any such nonsense. Can anyone confirm or deny what fagor states about following error?
    Thanks !
    Nov 2016
    3
    Re: low following error not a good thing?
    The amount of following error needed depends so much on what your doing, how fast you are doing it, what hardware you are doing it with, and how close of a tolerance is acceptable. If indeed they have said that, I would assume it is because it is simply a nice balance point for high precision versus high speed work. As you have found in tuning your equipment, you can achieve tighter following. Most of our equipment is running around .05 iirc. I would just monitor your servo system temperature closely while under load for a bit to be sure you are not over stressing your system by forcing it to hold such a tight margin.
  1. Good Morning All! Going nuts here! Getting error in inkscape when.....
    By Dipswit in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-17-2020, 05:35 PM
  2. Replies: 8
    Last Post: 02-06-2015, 03:56 PM
  3. Caught a good ID10T error on video.
    By pickled in forum Tormach Personal CNC Mill
    Last Post: 01-20-2015, 06:28 AM
  4. Reduction gearboxes on servos-good thing?
    By Splint in forum Linear and Rotary Motion
    Last Post: 05-28-2008, 06:32 AM
  5. Bit odd thing to look for... :)
    By jinu117 in forum Phase Converters
    Last Post: 12-13-2007, 10:48 PM
