587,997 active members*
1,748 visitors online*
Results 1 to 6 of 6
    Apr 2010
    486
    Lube metering unit
    Anyone have a good source for the lube metering unit?
    Tom
    Jan 2005
    15362
    TarHeelTom
    This is one of the places you can get them
    http://www.internationalscrew.com/pa..._injectors.htm
    Mactec54
    Dec 2003
    24220
    Best to replace them all and flush the lines out, also take the pump apart and clean the reservoir, the oil gets gummy after many years use.
    Al.
    Albert E.
    Sep 2003
    552
    Here is another.
    http://www.devcocorp.com/american/bijurmeters.htm
    The Bijur are about $20 and they have an aftermarket part for about $17.
    Darek
    Sep 2003
    552
    Quote Originally Posted by Al_The_Man View Post
    Al.
    Boy you are right there! Some of the old parafin based way oil if left idle would turn to wax!
    There is a filter element and screens at the bottum of the pump you should replace also.
    Darek
    Apr 2010
    486
    We have taken the pump completely apart and cleaned it. Working fine as a manual pump now.
    There was a ton of gunk in the bottom of the tank.
    We do plan to take off all the lines and flush them, but got to get oil past the tee first.
    Tom
  1. re Spindle Lube and Lube Pump
    By robkuhi in forum Tree
    Last Post: 10-24-2011, 06:49 PM
  2. metering valves for one shot oilers?
    By thomasfreedy in forum Benchtop Machines
    Last Post: 03-31-2009, 05:35 PM
  3. cleaning lubrication system metering valves
    By integerspin in forum Uncategorised MetalWorking Machines
    Last Post: 03-05-2009, 09:24 PM
  4. Series 1 Z Axis Lube Metering Unit
    By kewl_cat in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2009, 06:14 PM
  5. Metering/Dosing pump
    By pds in forum Mechanical Calculations/Engineering Design
    Last Post: 12-03-2008, 09:31 PM
