603,780 active members*
3,125 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > M-code for deckel maho 64V linear with Fanuc 16iMB controller
    Jun 2009
    146
    Can anyone help me with my problem on our "DMC 64V Deckel Maho Machine" with "Fanuc" controlls?
    I need now, how activating the touch probe, before I call the measure cycle.
    I need a list of M-functions to see what of M-function can be activated the sensor.
    Measuring cycles are called as G-functions (G2020, etc ...), but when I call one of thes cycles, the sensor is not activated.
    Jun 2011
    Is this a fault, that were from begin. In my machine, I bought the IR-eye for the touch-probe, because a later integration were much more expensive. When I want to first use the probe, the IR-Eye wasn't correct connected.
    Jun 2009
    146
    But if he was not properly connected, then it has not worked in the "JOG" mode, or is it?
    I can measuring in the "JOG" mode, but when I put the cycle in the program, then don`t work in "automatik" mode...
  1. Deckel Maho FP3- new project
    By keven88 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-05-2023, 09:50 AM
  2. deckel maho dmu 50 t
    By gunz in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-24-2021, 01:54 PM
  3. Deckel Maho DMU 50 VL
    By waltteris in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-13-2016, 09:32 PM
  4. DMG Deckel Maho Post
    By aldepoalo in forum BobCad-Cam
    Last Post: 03-24-2014, 03:05 PM
