588,548 active members*
5,958 visitors online*
Results 1 to 4 of 4
    May 2012
    537
    M code to "unwind" 4th axis
    Hi Tom,
    I need to make an M code to "unwind" my 4th axis. Im running a 4 axis surface here today and ending up at like 80,000 degrees when its done. Need something to take current A machine position, divide it by 360 degrees and reset position at closest multiple of turns to zero. Same as this: https://www.youtube.com/watch?v=vupmJflbAIE
    Im really busy with work at the moment and a little out of practice with c programming, wondering if you might be able to help me with this. Should be fairly simple.Thanks.
    Mark
    Aug 2009
    1573
    Re: M code to "unwind" 4th axis
    G28A0 maybe
    May 2006
    4060
    Hi Mark,
    See the Modulo360.c example:
    If your system has encoders the encoder would need to be adjusted also:
    Code:
    #include "KMotionDef.h"
    #define CNTS_PER_DEG 1000.0
    #define AXISA 4
    double modf(double, double *);    // returns integer part with more than 32-bit precision
    double floor(double x)            // truncate down toward -infinity
        double y;
        return (modf(x, &y) < 0 ? y - 1 : y);
    main()
        double dest = chan[AXISA].Dest;
        double cnts = CNTS_PER_DEG * 360.0;
        double delta = (floor(dest / cnts)) * cnts;
        WaitNextTimeSlice();        // Avoid interrupts
        DisableAxis(AXISA);
        chan[AXISA].Position -= delta;
        EnableAxisDest(AXISA, dest - delta);
    TK
    http://dynomotion.com
    May 2012
    537
    Awesome, that looks easy enough. Ill give it a try on the next 4th axis job. Thanks again.
  1. Need help working out feed rate for "C" Axis and "Z" axis simultaneously.
    By Jonaldhinio in forum Australia, New Zealand Club House
    Last Post: 08-12-2014, 09:27 AM
  2. Replies: 1
    Last Post: 07-16-2014, 04:13 PM
  3. Replies: 17
    Last Post: 02-22-2014, 06:58 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
