588,089 active members*
4,409 visitors online*
    Nov 2013
    78
    M115 x 10 mm thread 1200 mm long
    Is this type of thread achievable on a doosan puma 300 lb and can you get 10mm pitch inserts and holders ,any advice on this would be much appreciated
    Using Tapatalk
    Sep 2006
    607
    That is stretching it. You are close to the max travel of the machine, but it might work. At least that's what I can gather from the specs I just found. I'm currently running a Puma 280LM, which has a smaller work envelope, and the Z axis travel listed is without the chuck jaws as far as I can remember. The axis is also measured from the middle of the mounting face on the turret, so that takes away a bit as well.
    I would suggest to just home the machine and use a tape measure to verify weather it could work or not.
    You could use a TCMT insert if it's a standard 60 degree thread. The bottom radius would be .4mm I believe, and for that size thread it would most likely be acceptable.
    Nov 2013
    78
    Thank you I tried it today and I was getting massive vibes because I haven't got a steady think I might have to sub them out
    Using Tapatalk
  1. 1200 by 1200 machine build
    By Rodm1954 in forum DIY CNC Router Table Machines
    Last Post: 05-04-2012, 01:55 AM
  2. Cutting Long Metric Thread
    By stuby in forum MetalWork Discussion
    Last Post: 08-30-2011, 05:30 PM
  3. Long full acme thread machining
    By Jelle_b_k in forum MetalWork Discussion
    Last Post: 08-20-2011, 02:01 PM
  4. Old big long thread on UHU servo controller.
    By vroemm in forum UHU Servo Controllers
    Last Post: 06-30-2008, 08:21 AM
  5. 1200....
    By hardmill in forum Community Club House
    Last Post: 07-12-2003, 09:30 AM
