587,832 active members*
3,754 visitors online*
Results 1 to 17 of 17
    Jun 2008
    33
    m30 x 3.5 tap speed?
    material A36.
    machine is a VF3,30 horse, gear driven. 50 taper.
    tapping 2'' deep. The tap is 4 fluted.
    im thinkn of starting out about 100-125rpm.
    ill be holding the tap in a collet so im worried that it will slip in collet running the torque its going to require to tap 2'' deep.
    any thoughts would be great.
    thanks.
    Nov 2007
    1702
    Edit: I'm a moron. I read the original post as a 3.0 mm tap, 3" deep, not a 30 mm. Never mind. That's a huge tap. Ram that sucker in there.
    Greg
    the collet will probably slip pecking or straight tapping
    your best bet is to ditch the collet holder and make a sleeve to fit the tap into a sidelock ,other than that i cant see any reason you can't tap 2" deep if its spiral flute , ive done it many times with near the same or larger dia taps to more depth , chances of breaking the tap is slim to non if it is of any quality ,
    if your tapping multiple holes then i would suggest monitoring the tap in between holes and watch that your not building a bird nest around the tap because it will do damage
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Aug 2007
    558
    Greg - you had me worried there I thought I was a bit of a small thinker for a while - wow, I thought. M30 is a small tap. He must do some BIG work!
    Jason
    Nov 2007
    1702
    Yeah, I was looking at some really small taps the other day. I read the post and wondered how sombody would push a 3.0 mm tap through 17D worth of steel. :withstupi
    Greg
    Jul 2007
    148
    How about thread milling it?
    Jun 2008
    33
    well i went in for the kill today and ran the big M30x3.5, 4 flute, bottom tap 2 inches deep,3 times.
    I used a speed of 120 and a feed of 16.5354. i flooded it with coolant and let her rip, it did awesome. Im holding it in a large collet so ill keep an eye on the holder cap loosening or slippage.
    Thread milling was not an option due to cost and hard to find mill body to insert type and ive never thread mill before, i would love to master it though.
    May 2005
    8
    Talking Vardex thread mills
    You can try Vardex thread mills. I've thread milled some pretty big threads with them. Vardex has software that will write code you can cut and paste.
    It's really very easy!:cheers:
    Aug 2005
    578
    You could have bought two thread mills for the price of that tap....
    And it would do the job nicer and faster. Not to mention lasting longer....
    Quote Originally Posted by PBMW View Post
    nicer ?
    threadmilling will take a lot longer amount of time if there are multiple holes
    Apr 2012
    12
    Re: m30 x 3.5 tap speed?
    I know this is an old thread but I'm tapping some M30 Holes 2" deep with an OSG spiral flute. Had a lot of trouble with the threads gaulding. Opened the minor dia up a little and that helped, but occasionally the tap will really trash up a few threads? Generally at the bottom of hole. Using a floating head. Could a rigid tap cycle help with this? Thanks
    Mar 2010
    1852
    Quote Originally Posted by Ronniewhite70 View Post
    What size hole are you using? What as lubricant?
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Apr 2012
    12
    I've got the hole at top of tolerance 26.768(1.052). Using a semi synthetic mixed at 5%...rpm of 110
    Sep 2010
    1230
    Hi Ronnie,
    When tapping to the bottom of a blind hole, rigid tapping is preferable if the only floating holder is of a standard type without any length positioning capabilities. Tapping to the bottom of a blind hole with a Floating Holder is reliable by using the type of holder that will allow the tap to stop rotating whilst the holder freewheel with the spindle around the stationary tap. In use, the Tapping Cycle has a Dwell specified when the Z axis reaches the Z coordinate of the cycle. Because the Z axis is stopped but the spindle is still revolving, the tap continues to feed, thus extending the floating holder until the internal drive finds the freewheel zone (usually an annular groove in which a drive dog is able to freewheel). After the Dwell period, the spindle will reverse but the tap remains stationary until the drive engages again as the Z axis feeds in the reverse direction.
    The best method of all, in my opinion, would be to Thread Mill a thread of that size using a multi-tooth Thread Mill. Start at the bottom of the hole Climb Mill to the top leaving the swarf behind,
    Regards,
    Bill
    Mar 2010
    1852
    Didn't see the material, but you can open the hole up more. Your hole size if for a 75% thread at no more than one depth of the tap, (about 1.180"). When tapping deeper hole you need to go larger and get into the 55% range or you will have issues.
    For example, a 1 3/16" x 12 tap has a minimum hole size of 1.097" for a short hole, but at one and a half to twice the tap width depth, it is a maximum of 1.120." Open up your hole and it will be much better.
    In that size it wold be better to thread mill, but that mill would be very expensive.
    Mike
    Apr 2012
    12
    Thanks everyone. I do a lot of thread milling. But there are 22 holes in each part and 33 parts to run. I have the minor dia opened up to the top of tolerance. May just have to thrd mill and sacrifice a little machine time..
  17. #17
    Apr 2012
    12
  1. 180V DC Motor Speed control Neco speed controller card - PLEASE HELP
    By gridevolver in forum CNC Machine Related Electronics
    Last Post: 01-22-2019, 06:44 PM
  2. Replies: 0
    Last Post: 12-13-2013, 07:13 PM
  3. Replies: 0
    Last Post: 06-11-2010, 07:59 AM
  4. Cutting speed locked to Z torch height control speed
    By Beefy in forum Mach Plasma / Laser
    Last Post: 02-15-2010, 12:14 AM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
