586,036 active members*
3,832 visitors online*
Results 1 to 4 of 4
    Nov 2017
    7
    M3000 with M24 board not starting up
    the pendant doesn't load when I power up, checked 5 volt,24 volt and 220 3 phase,
    there are 2 red lights on the M24 board , on the top red light reads VERTEX and on bottom left a red light CTS,
    I have gone thru the original schematics but cant find anything.
    fan on spindle is on,fans inside cabinet are on, the inverter is not on,what should I check?
    Jun 2005
    1730
    Re: M3000 with M24 board not starting up
    Post the schematic and we can review
    Jul 2022
    HI there I am looking for schematics for the M2521 board from the Multicam CNC 5000 series
    Apr 2016
    7
    You could try opening MultiCam Motion Mechanic with the connected computer.
    While the board is booting, it should output some startup info, and possible error messages there.
    After connecting the COM port and opening the terminal, just press the little white button on the controller board (reset button).
  1. M24 Board and Pendant for sale
    By Parkgrr in forum Multicam Machines
    Last Post: 08-21-2021, 12:49 AM
  2. M3000 starting job then nothing
    By bishopplastics in forum Multicam Machines
    Last Post: 09-03-2020, 07:44 PM
  3. ATC-firmware for M24-5 board - looking for
    By keesfrees in forum Multicam Machines
    Last Post: 04-28-2015, 10:17 PM
  4. Looking for a Multicam M24 K520 Control Board
    By Chiefst in forum Multicam Machines
    Last Post: 12-08-2011, 11:08 PM
