M32 controller questions..
Just got a new (to us) Mazak v550b mill with a m32 controller. I have a few questions hopefully someone can answer.
1. Does anyone know what parameter(s) for the 4th axis control the error? At the moment when we rotate the axis 360 degrees, it actually moves approx 369.88. And it repeats.
2. When trying to load comments with an EIA/ISO (g-code) program the controller craps out and won't load the program. Is there a size limitation or something?
3. What is the proper way to jump to a certain block in an EIA/ISO program?
4. How can you change G84 tapping cycle to use IPM instead of IPR?
5. Is there some parameter setting for the 4th axis to use M10/M11 (unclamp/clamp) ?
Thanks for any help you can give me.. I greatly appreciate it.
Just when you thought you had it all figured out, all hell breaks loose..
