Using a Fanuc 18i-TB control, if M58 is enabled, if you enter G0, it is disabled. Does it become enabled again if you enter a G1, or do you have to enter M59 before the G0 and then reenter the M58 to reenable the tool load monitoring?
your M58/M59 is custom for your machine so we can't help with specifics.
generally you enable TLM then the machine will monitor the load while feeding until you cancel it.
if you do a G00 but don't cancel TLM it is still active regardless. But the machine will only monitor load when doing G01/G02/G03
