Is there a way to make mach2 generate gcode with the feedrate other then 1 is this a default that can be changed.
Are you using Lazy Cam? If so, set the feedrate in the layers tab (you usually have to resize the tab to see all the options.
Regards
XTCNC
Just add the feedrate to your g-code, F50 for 50ipm, or type the feedrate you want in the DRO and hit enter.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
Im useing a .dfx file imported into mach 3 and automaticly translated into gcode, the problem Im having is that the feed is always set to 1, I then have to manualy set to desired feed. What im wondering is if there is a way to change mach 3 to always translate to desired feed that i want.
Mach2 or 3? In the Mach2 .dxf importer, I believe you can assign feedrates to the different layers in the .dxf during the import.
Gerry
Well just from what you told me, that lead me to figure out the rest. Thanks again ger.
