587,180 active members*
5,264 visitors online*
    Jul 2008
    4
    Mach 3 cable connection
    I am very new to using CNC router and Mach 3. I just received a new to me CNC router and I would like to connect my other machine computer to the new one. But I need a male to male parallel cable and I am having a hard time finding one locally. Will Mach 3 work with a USB to parallel adapter? Thanks for any help.
    Dec 2008
    226
    Pretty much a resounding no, hate to disappoint you.
    I'd use a m-f cable and a m-m adapter then..
    unless you KNOW that you are getting a 25pin straight through male to male... be careful its not a null-modem cable or not all 25pins connected... male to female are more common as "Extension Cables" so all pins straight through....
  1. PC <-> Brother TC-S2A - cable ok, no connection
    By mahi in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-10-2022, 08:58 AM
  2. Replies: 0
    Last Post: 01-22-2010, 07:06 PM
  3. Replies: 1
    Last Post: 07-21-2009, 03:23 PM
  4. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
  5. cable advice for heidenhien connection
    By Rousey in forum DNC Problems and Solutions
    Last Post: 11-02-2006, 12:24 AM
