587,737 active members*
3,195 visitors online*
Results 1 to 4 of 4
    Dec 2016
    Question Mach 3 cutting half the distance/size
    Hello,
    I am back working on some cnc router stuff and had to reload mach I set it up as per mfg settings again. I had the issue before of it cutting half the distance and changed a setting to get it right but do not remember what setting I was ? Any help would be appreciated.
    Dec 2013
    5716
    Re: Mach 3 cutting half the distance/size
    Steps per unit possibly?
    Sep 2016
    20
    That would be the scale factor in the screen for 'Program Run' just to the left of the toolpath display. Remember to press the Enter key after entering a scale to make the change persist.
    Cheers
    Aug 2015
    52
    Attachment 344682
    Please check steps per .
    it is very important for the machine ,if steps per is not right ,the real distance of the machine will be not correct .
    here is a way to test and adjust it .
    1,please make a design ,let the machine move 100 mm(or more ,if your machine very big .)
    2,use a ruler measure the real distance.
    3,Compare the difference between actual and design values。
    FOR EXAMPLE .
    you let y axis move 200mm (the screen show .)
    but the real distance is 180mm( the ruler measure .)
    and now our steps per is 104.37.
    Attachment 344684
    Jinan Blue Elephant CNC Machinery Co.,Ltd
    Contact:Jack
    Email:[email protected]
    Whatsapp/mobile/Wechat:0086-15064026772
    Skype:elephantcnc
    QQ:3001738567
    Web:Jinan Blue Elephant CNC Machinery Co.,Ltd.
    To be first brand CNC Router Manufacturer & Wholesaler Platform
  1. ISA Half-Size CPU board for EZ Trak
    By md63825 in forum Bridgeport / Hardinge Mills
    Last Post: 06-08-2016, 08:20 PM
  2. x axis onlycutting half size
    By gerry2717 in forum Mach Software (ArtSoft software)
    Last Post: 09-29-2014, 02:00 AM
  3. Displaying half the real distance
    By Shaun Smth in forum Fadal
    Last Post: 09-21-2012, 03:01 AM
  4. Half size?
    By nalmeida in forum Joes CNC Model 2006
    Last Post: 01-16-2008, 06:15 PM
  5. Full/Half/Quarter/Eight Step Size?
    By pminmo in forum Polls
    Last Post: 01-11-2006, 07:31 PM
