603,900 active members*
3,509 visitors online*
Page 1 of 2 12
Results 1 to 20 of 27
    Aug 2007
    16
    Question MACH 3 cycle start button
    Hi - I need to have a "CYCLE START" push button instead of having to use a mouse and click on the "CYCLE START" button on the monitor. Any one have a fix for this problem or where I can go to get info. I am using the software and stepper motors to run a machine other than a cnc mill. So I have to run a cycle, load the machine and run another cycle.
    Mar 2003
    35494
    Just connect a button to an unused input pin. You assign an OEM Trigger to it in ports and pins.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2007
    4550
    Post
    Rick,
    I have attached a few jpgs to explain the procedure.
    1: Assign the port and pin to OEM code 1
    2: Assign OEM Code 1000 to Trigger 1
    3: Attach switch to appropriate pin on your breakout board "in the example pin 15"
    4: finished.
    Hope this helps,
    Jeff....
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Mar 2003
    35494
    Jeff, I think you need to also set the hotkey for the OEM trigger to match the cycle start hotkey. Right?
    Gerry
    Feb 2007
    4550
    Post
    Gerry,
    I have set it up without the hotkey and it works fine however I guess you could add the hotkey code "2162"
    Jeff...
    Mar 2003
    35494
    I don't think you can type the code, you actually have to hit the key. But if it works without it, then no need to.
    I didn't look at the secind image you posted. Setting the OEM code apparently does the same thing as setting the Hotkey.
    Thanks for the clarification.
    Gerry
    Aug 2007
    16
    Smile MACH 3 Button
    Thanks for all the help. I think I can get it work now
    Jun 2007
    3738
    I will use it too.
    Thanks for thinking out this one.
    I updated to a touch screen, instead of adding a button.
    Still really need the button though.:devious:
    Added the button. Dry dusty fingers no good on touch screen.
    Thanks Jeff!!
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Feb 2007
    4550
    Neil & Rick,
    You are very welcome.
    I am happy to be able to help and contribute back to a super bunch of very talented guys.
    Jeff...
    Sep 2010
    start cycle
    Quote Originally Posted by jalessi View Post
    Gerry,
    Jeff...
    Hello about start cycle with outside star buton.
    How to connect start buton with LPT port and what is comand in G code
    Please send me full information how to connecting and setup and programing
    Sep 2010
    mach 3
    Quote Originally Posted by Rick7702 View Post
    Hello
    I also need tohave "Start Cycle " push button with cable to controler.How to conect betwen witch pin for exampel 14 is free and ground .and what i to write in G code.
    Do you have full info about this
    Feb 2007
    4550
    Post
    Bpetkov,
    Pin 14 is a output it will not control the cyclestart, that requires a input pin
    Jeff...
    Jun 2007
    3738
    Look at post #3
    It is all there and it works.
    Nov 2005
    77
    Hi guys - I am having a bit of trouble with this. This is on my small mill drill and I am using a G540 with no luck. I have tried assigning an input to input 1, 4 and oem trigger 1 using code 1000 and assigning a hot key. I am uing a new down load of mach3. As I write this I realize I have not loaded the license yet. Might be the issue. I will test that next. Any help would be appreciated. Thanks Ron
    Nov 2005
    77
    It now works - Post #3 and a pair of glasses and it will work quite nicely
    Sep 2006
    20
    Start, Stop, Feed Hold
    Well, I have similar problem. I can add control for start, stop and feed hold using OEM trigers. But, if I use stop-start sequence I must turn on spindle manual. Feed Hold is ideal, since doesn't turn off spindle, but delay is about 2 sec. How I can change delay for Feed Hold?
    In other words, I must synchronize some actuators with spindle rotation, (like threading) so spindle must works always, and X axis periodically.
  17. #17
    Oct 2005
    I'm trying to connect a switch to ref/all by using my free input 14 trigger 1 OEM code 105. When I press the switch all I get to set is the Z axis it won't go to X and Y after, but when I press the ref/all (home) on the screen or with the keyboard everything works good. Anyone have any idea what to do to fix this problem?
  18. #18
    Feb 2007
    4550
    Quote Originally Posted by bartkuzar View Post
    Try OEM code 138, please post your results.
    Jeff...
  19. #19
    Oct 2005
    Thanks I did tried the OEM 138 and works no problem but it will just go home (x0y0z0) it won't set the coords I wonder if there is some other thing that I should do.
    Thanks again Jeff
  20. #20
    Oct 2005
    I just wonder if anyone have tried this OEM code 105 and if was able to reference all Z,X,Y or just Z. ?
Page 1 of 2 12
  1. Start macro with input button
    By geahr in forum Mach Software (ArtSoft software)
    Last Post: 09-17-2009, 03:52 PM
  2. Need Help for Mach 3 Macro+Start by ext.Button
    By Morianer in forum Mach Software (ArtSoft software)
    Last Post: 07-16-2009, 08:15 AM
  3. Can spindle start when you hit the Z-axis button?
    By moldcore in forum Milltronics
    Last Post: 04-26-2009, 02:14 PM
  4. Interact 412 - CYCLE BUTTON RESTART SPINDLE
    By Zhales in forum Bridgeport / Hardinge Mills
    Last Post: 07-20-2007, 01:46 PM
  5. Cycle Start button
    By kaleem1 in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 09:05 PM
