603,864 active members*
5,602 visitors online*
Results 1 to 5 of 5
    Jan 2011
    Mach 3 DRO/Gcode doesn't match
    Hey guys. Sort of a noob to CNC, not so much to machining.
    Here's the deal. I've got my CNC machine all set up, and I'm using Mach 3. I can go anywhere in my 98"x50" table within 0.003." I am certain that my backlash is compensated properly, I am not missing any steps, and that my steps per are dead on. In short, if I enter the MDI screen and give a "g0" instruction, the machine goes exactly where I expect it to, and the on-screen DRO and real-life measurements reflect that.
    My problem arises when I am running G-code. My on-screen DRO (incidentally where the real life tool is) gets out of sync with the G-code instructions.
    You can see from the screenshot below that I am stepping the G-Code with the "Single BLK" command and that Mach3 just received the "G1 9.6894" command, but my router actually moved to +9.7064, which is 17 thousanths out! This is verified by real life measurement.
    Here are the links to my G-Code.
    Part I'm discussing
    Other Part I'm having trouble with
    I'm not sure what I'm supposed to do here, the errors seem to be random anywhere up to 0.035". I have tried enabling/disabling backlash compensation (and restarting program like it says), it only makes things worse due to wiggly backlash.
    The crazy thing is, if I stop the G-code, click "goto z" and then goto the MDI page, it now includes that stupid offset. For example "G0 y0.2" goes to +0.217, no matter what I "G0" it adds .017 to it and sends that to the DRO and the machine.
    Please help a confused man.
    -GB Ward
    Mar 2003
    35494
    What are your steps/unit set to?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2011
    X Axis:
    Steps Per: 1419.221006
    Velocity: 469.68
    Acceleration: 10.019581
    Y Axis:
    Steps Per: 1418.450557
    Velocity: 469.44
    Acceleration: 10.015506
    Z Axis:
    Steps Per: 8024.030299
    Velocity: 30
    Acceleration: 3
    Mar 2003
    35494
    How old is that version of Mach3? Looks like 2.63 maybe?
    I'd recommend a newer version first.
    Another guess it's it's related to CV and backlash comp.
    Gerry
    Jan 2011
    Thanks. Upgrading appears to work.
  1. NM-145 Mach 3 Gcode scaling error?
    By CNCwilson in forum Novakon
    Last Post: 03-03-2011, 04:30 AM
  2. Mach 3 GCode Error
    By stabbs in forum Mach Software (ArtSoft software)
    Last Post: 08-21-2009, 07:02 PM
  3. Mach 3 reacting to my GCode crazy!
    By WarrenW in forum Mach Software (ArtSoft software)
    Last Post: 02-19-2006, 10:44 PM
  4. Mach 3 GCode Question
    Last Post: 01-10-2006, 07:43 PM
  5. Mach / GCode question
    Last Post: 11-19-2005, 08:21 PM
