Hello
Is it possible to use linear scale encoders with mach 3 ???
Hello
Mach3 does not accept encoder feedback. You could use servo drives which accept step and direction signals from mach3 and use linear scale encoders with them.
Matt
If there is any significant backlash present when using linear scales Without a dual feedback system, (motor encoder and linear scale), the result is usually high instability.
Al.
Albert E.
