I've had my 4'x4' router going now for about 3 months - not my first machine but my first mach 3 machine. It has seen about 100 hrs? of use without a problem( that I couldn't figure out). Last night I was running a program and it previewed OK - had a couple stray circles, but those have never cause a problem in the past. About 4000 lines in it plunged my Z axis straight down through my table. I was able to repeat this 3 times at the same spot( not close to one of the stray circles). I removed approx 20 lines of code and it pass right by. It was programmed by mastercam 7, which generates lots of G02,G03 arc commands.
Could mach3 be having a trouble with a arc command that causes the z axis to plunge like that. The strange part is - when I stop it right before it hits the table the DRO's are still at the old position.
Anybody else have this problem, what was a cure? Loosening the tolerances in Mastercam maybe so the arcs have a smaller radius?
Fred
