587,180 active members*
4,886 visitors online*
Page 2 of 2 12
Results 21 to 29 of 29
  1. #21
    Feb 2015
    113
    Re: Mach 3 Kernel Speed Setting and motor tuning
    You may not be able to. You can sometimes change it in Device Manager, under Computer, but it may require re-installing Windows.
    Did you read through the thread on the Machsupport forum?
    Yes i read it ... But it says windows vista, i have 7.. i will try it and see if it help . Thank you
    Sent from my ONEPLUS A3000 using Tapatalk
  2. #22
    Apr 2013
    1899
    Quote Originally Posted by assadi View Post
    believe it or not before asking i tried to read the manual but nothing ... Help can also be link/video.... Not just spoon feed
    http://www.gigabyte.se/Motherboard/G...DDR3-rev-10#ov
    I checked the manual and it is pretty clear to me. Have you updated the BIOS and the chipset utilities? Download and update. Also, the card does not have a printer port, so maybe your printer ports are faulty... only you can find that out, or ask for support from the supplier, or find a PC support discussion forum if you suspect that the PC is wrong. Mach3 works excellent even with W10 64-bit. Of course, parallel port is no longer supported, but that's a dinosaur anyway. Really, I can't understand why at all use it. There are so many USB and ethernet motion controllers out there, buy a cheap UC100USB and you'll never look back. That is the easiest solution. If you still have problems after that then at least you'll know it is NOT the parallel port.
  3. #23
    Feb 2015
    113
    Ok, I'm not able to solve this problem... I just ordered the ESS Smooth stepper... I hope it will fix my problem... If not I Would Set Myself on fire 🔥 on the machine 😥
  4. #24
    Feb 2015
    113
    Ok i fix it... Without the Ess, tomorrow i will receive it. On my old PC it's was older version of mach3​ with license. On the new pc i installed a newer version (I thought it will be better with Windows 7)... And I copied the profile file from the older version to the new one... Now I uninstalled the new version deleted all the drivers and files and installed​ the older one ... It work fine ... On the new version i had difference between the kernel speed i set and the reading in diagnose screen inside mach3 ... When i set kernel to 25khz the frequency pulse reading in diagnostics screen was maximum 4000hz . Kernel speed 35khz give around 11000hz and kernel 45000 give around 35000hz ... Now in the older version they are the same ...
    Thank you all for help and appreciate that .
  5. #25
    Apr 2013
    1899
    Good to hear that you fixed it. Good luck using it as well.
  6. #26
    Feb 2015
    113
    Quote Originally Posted by A_Camera View Post
    Thank you for the help
  7. #27
    Jul 2017
    25Khz is all that you need.
    At 15240mm/min, you have about 976,579 steps min, which is only 16,276 steps/second.
    25Khz will give you 25,000 steps/second
    But we have 3axis, or maybe 4axis.. it can be 16,276x4=65,104 roughly.. if that is right then 25khz is not enough.. is that right?
  8. #28
    Nov 2012
    1270
    Quote Originally Posted by 1elanrivera View Post
    Parallel port outputs all signals, well, in parallel. So the kernel speed requirements stay the same for any number of axes.
  9. #29
    Jan 2005
    15362
    A setting of 45Khz to 60Khz work very well with most computers, if you use a external CPU like the UC-100 or SmoothStepper then they start at 100Khz and then the computer does not need much processing power
    Mactec54
Page 2 of 2 12
  1. Microstep Setting & Kernel Speed?
    By Contract_Pilot in forum Mach Software (ArtSoft software)
    Last Post: 01-25-2015, 10:11 PM
  2. Replies: 0
    Last Post: 05-25-2013, 11:13 PM
  3. Mach 3 motor tuning
    By corneliusbrown in forum Mach Software (ArtSoft software)
    Last Post: 01-27-2011, 11:15 PM
  4. Mach 3 Kernel Speed
    By saabman in forum Charter Oak Automation Support Forum
    Last Post: 01-18-2011, 12:21 AM
  5. Help with setting up motor tuning
    By tdnp in forum DIY CNC Router Table Machines
    Last Post: 12-23-2010, 02:57 AM
