603,407 active members*
2,218 visitors online*
Results 1 to 7 of 7
    Feb 2009
    3
    Mach 3 Plasma Setup Tutorial
    Hi all.
    I am currently a high school student in Australia.
    Over the last 6 months I have been building a CNC Plasma Cutter for my Year 12 major Metalwork Project. I have 2 week to reassemble (just painted today) and test. I have not had much time to look at and play with Mach 3 and am looking for a point in the direction of a plasma specific setup tutorial, or someone who can guide me through the setup.
    All my control electronics have been purchased from www.oceancontrols.com.au.
    My setup is:
    Solid edge
    v
    SheetCam
    v
    Mach3
    v
    BOB
    v
    4axis -- 4 steppers, X+A slave, Y, Z
    relay1 -- Plasma cutter, contact with work, then push button to start arc (button will be relay)
    limits -- looped for each axis
    I can and have set up all the motors to run but am not quite sure how to get the relay for torch control to work.
    Cheers
    Charlie
    Oct 2007
    1072
    mach3
    are you parallel port to the computer or usb
    What 2 contacts did you use to turn the torch on
    Feb 2009
    3
    Hi woodman08,
    1- Parallel port interface
    2- torch is on pin 17
    Oct 2007
    1072
    thanks for the info on the torch contact
    so the torch on/off # 17 and ground are these the two ?
    Also mach3 is a good choice as we have been using flashcut and i don't think its good for plasma.
    Feb 2009
    3
    Yes is 17 a relay on my BOB that controls torch on/off, so ground for the torch is the com on the relay.
    ive found mach3 to be the most supported, so thats why i went with it
    Oct 2007
    1072
    torch on off
    I am not 100% sure but if your relay is connected on pin#17 and common the the M command in mach3 will turn the troch on and off.
    I should be into this type of confuration this month so i will be in the same boat and will let you know how i fair out using what i am saying.
    I will be setting up the computer this coming week and i should know more.
    Mar 2010
    well the torch on/off will be generated from lazycam when u get g code
    and mach3 will excute that auto.
    try and tell
    thanks
  1. Download Mach 3 Tutorial Video
    By Huzzah in forum Mach Software (ArtSoft software)
    Last Post: 05-08-2010, 02:47 PM
  2. New Plasma setup
    By gfelippo in forum Torchmate
    Last Post: 09-30-2008, 10:58 PM
  3. CNC Plasma Cutting Video Tutorial Series
    By ivanirons in forum Waterjet General Topics
    Last Post: 12-18-2007, 02:29 PM
  4. Mach 3 Tutorial Downloading
    By Mr.Chips in forum Mach Software (ArtSoft software)
    Last Post: 10-21-2007, 11:03 PM
  5. Mach Screens tutorial 2 of 3 ( Video)
    By ynneb in forum Screen Layouts, Post Processors & Misc
    Last Post: 07-05-2006, 11:01 AM
