603,336 active members*
4,041 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach 3 and UC100 usb motion control install problem....
Results 1 to 7 of 7
    Oct 2007
    446
    Question Mach 3 and UC100 usb motion control install problem....
    So I finally got to the point of getting my home cnc machine ready for running.
    Problems right off the get go with the driver install.
    I'm installing on a windows 7 64bit system.
    version of Mach 3 is Version R3.043.066
    and installing a UC100 USB motion controller (V2.148) since there is no parallel port.
    When I start mach these errors pop up:
    Plugin DLL Defective. Reload
    UC100 V2_148.dll - Defective Plugin Found..ignoring
    So now what ?!
    Do I have to update Mach3?
    Do I have to update the uc100?
    any help much appreciated,
    thx
    Mar 2003
    35494
    Re: Mach 3 and UC100 usb motion control install problem....
    I'd delete all the files from the mach3\plugins folder, then reinstall the plugin for the if100
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2007
    446
    rookie mistake....
    didn't realize you actually have to have the controller actually plugged in for the drivers to actually install properly...fixed now
    Oct 2007
    446
    in mach 3 in ports and pins
    what do i need to set for my port address? where do i find this.
    currently its 0x378 which is a printer port to my understanding...since i'm not using a printer port and the uc100 instead, i assume this needs to be changed???
    Mar 2003
    35494
    No, the port setting is not used with the uc100
    Gerry
    Oct 2007
    446
    Do i need to un check port 1 or delete the number from the port address ?
    Mar 2003
    35494
    I don't think it matters, but I'd uncheck it.
    Have you read the uc100 manual?
    Gerry
  1. UC100 USB Motion controller
    By PhilipG in forum Mach Software (ArtSoft software)
    Last Post: 01-24-2016, 05:02 AM
  2. USB Smoothstepper WIN7 install: Crashing Mach 3 - need help please.
    By demonx in forum SmoothStepper Motion Control
    Last Post: 12-12-2014, 05:50 AM
  3. Mach 3 + G540 + UC100 + WJ200 = Can't run spindle from Mach 3?
    By zer0fighter in forum Benchtop Machines
    Last Post: 09-08-2013, 10:54 PM
  4. Problem with jog functions control panel after lcd monitor install
    By i_fab2 in forum Centroid CNC Control Products
    Last Post: 04-14-2013, 03:54 PM
  5. Motion Control Problem with Servo Amp
    By parkerbender in forum HURCO
    Last Post: 01-27-2011, 09:35 AM
